Is there a way to run a event when 2 sensors get the same value as trigger?
I know its possible with on/off but now its about temperature sensors inside and outside.
This way i want to trigger a event that if the outside temperature goes equal to the inside temperature i need to close the windows/doors if sensor says they are open, to keep it cooler inside then outside after letting the colder air in @ night.
2 devices same value event trigger?
Re: 2 devices same value event trigger?
From the homeseer board i got this reply:
&If hs.devicevalue("T1") >= hs.devicevalue("T2") Then hs.triggerevent "Temp Alarm"
Works great, when inside temperature is equal to outside the event gets triggered.
Good to see that you still answer your own question for others!
Alexander
Always keep searching if i can find the answers faster then u can reply
So far the homeseer board was faster after 80+ views here, and now i try to educate u so u dont have to search for the answer
That line looks logical, but where do you put it?
Is it an event-trigger or a condition for an event-trigger?
Or is it an event-action, or part of a script (if so then what is the trigger)?
Got this as a "Recurring every 5 minute(s)" that runs this as script: &If hs.devicevalue("\9") >= hs.devicevalue("\11") Then hs.triggerevent "Temp Alarm"
This means it will trigger a manual only event called: Temp Alarm
