friends,
For a project i'm searching for a good solution without high costs. I need to find a way to get an external button connected to a pc and signal the push and I need to switch on a LED (12V) which is in the switch (http://www.okaphone.com/artikel.asp?id=460084).
I was thinking of disambling an ordinary keyboard and replace one of the LEDs (Scroll-lock, numlock or capslock) with a relais (so a second circuit can provide the 12V line to the LED in the switch). With software i can turn on this relais by activating the function and recognize the push of the button by wiring a normal key of the same keyboard and signal the push by software.
I'd hoped there is an small keyboard (numeric) with LED for those functions, but i can't find one. I could also use a gamepad, but than i need to figure it out within the software to signal the push (and still need to activate a LED) and that is more code than for a regular keyboard.
Any other solutions or found a numeric keyboard with LEDs (and not a power-signal led!) ? Please respond!
Input & Output to/from PC
Alexander
Re: Input & Output to/from PC
Parallel port maybe. I am switching 8 relais here with it and you can also use it for reading data.
It's easy to connect and most printer are connected via usb nowaday.
Alexander
Do parallel ports still exist
In that case i have a Velleman K-8000 for you.
You can have it for free if you want, i don't use it.
Thanhks Alexander !!Alexander wrote:thanks!!: http://www.epanorama.net/circuits/paral ... html#input
you can send file by my mail.
RS232- RS485, Ethernet - RS232 can connect and most printer, PC, control are connected.
But i don't know how does it active??
