New action type: Execute external program
Moderator: RDNZL
hhg
Post by hhg »
Hi
Still very new to DomotiGa and this forum, but I'm being more and more impressed by Domotiga - A very flexible HA program.
I have a need to reconfigure my camera at sunset and sunrise, and was thinking: Well, DomotiGa knows when it is sunset...
So I added a new action type: Execute external program. See attached screen shot.
Edit Action Form
Edit Action Form
The patch is against revision 372. I hope others will find it useful. And that Ron will include it in a future version.
Best regards
hhg
execute_action.patch.tar.gz
(881 Bytes) Downloaded 307 times
RDNZL
Re: New action type: Execute external program
Post by RDNZL »
thanks for your work!
Will add it to the code repository once I have cleared my jet-lag after returning yesterday from a long stay in Indonesia.
Will also post other DomotiGa code still laying around here.
Regards, Ron.
RDNZL
Post by RDNZL »
I have added your code to revision 390.
Thanks.
Regards, Ron.
hhg
Post by hhg »
Hi Ron
Thanks for adding.
I've noticed you added (in rev 391) code to set the tab index. That is actually already handlet in your code in line 56-63 IF the table actiontypes is populated - Or are you going to dump this table? Is it used for anything else?
It could be replaced with this line:
tabActionTypes.Index = rResult!type - 1
Either way, it work as it is, i've was just wondering...
Best regards
hhg
RDNZL
Post by RDNZL »
For some reason it didn't work the way I wanted, but I will review the code and change it back if needed.
Regards, Ron.
Return to “DomotiGa Forum”
