Using camera's as motion detectors with Blue Iris and HS
Posted: Sun Aug 15, 2010 12:04 pm
by Droezel
I thought I'd share this one with you all.
Yesterday I purchased the Blue Iris camera recording software (http://blueirissoftware.com/) I Must say it works truly superb for its price ($49.95) compared to other software packages.
I'm using 5 Axis camera's and a Foscam PTZ inside my house and got the idea to use them as a motion detector.
I set up a new virtual Windows Server 2008 x86 with 1gb of RAM, installed and configured the Blue Iris software (needed to disable UAC and install the Windows Desktop Experience to make in work). The Blue Iris software runs as a service on the virtual machine so I do not have to log on to the machine.
To communicate with Homeseer I also installed the Homeseer speaker client on the server, it does not have to be running but by installing it you can use HS scripting commands in a vbscript file.
In Homeseer, create an event you want to trigger in case of motion, for example:
Create a vbs file on your machine with Blue Iris installed and put this in it:
strEvent = Wscript.Arguments(0)
Set hsi = CreateObject("HomeSeer2.application")
hsi.SetHost("10.111.0.2:8742")
rval = hsi.Connect("username", "password")
If rval <> "" Then
   MsgBox(rval)
End If
Set hs = hsi.GetHSRef
hs.triggerEvent strEvent
Last step is to configure blue Iris to enable motion detection and enable an alert as shown below:
I must say this really works very good, I have 3 virtual machines running with HyperV on an intel 3Ghz Core2 with 8Gb of RAM. The BlueIris software recording 6 camera's uses almost no CPU.
Re: Using camera's as motion detectors with Blue Iris and HS
Posted: Sun Aug 15, 2010 2:04 pm
by drmacchi
Hi , i have it since some time.
this is my old post
http://www.domoticaforum.eu/viewtopic.php?f=14&t=2113
What will be powerful is a script from HS that could move PTZ cam to some preset positions (like Ninja plugin HS)
ciao !
