Here is a patch that puts the device status change back in CheckDeviceChangeEvents and it fixes the Dark boolean in CheckCondition.
I hope the latter works for everyone and that it doesn't wreck something else. (It doesn't as far as i could tell anyway).
I think these are temporary fixes as Geert-Jan van den Hurk is already working on the code as far as i understand.
Patch for Events (It's dark condition)
Moderator: RDNZL
- diff.tar.gz
- Fixes voor Events.module
- (439 Bytes) Downloaded 298 times
- RDNZL
Re: Patch for Events (It's dark condition)
Thanks will add it, Geerts-Jans code is much cleaner than mine, but certain conditions where not checked.
So I reversed some changes back until I have more time to investigate this, the events module is one of the difficult parts although it doesn't seem like that if you take a quick look at it...
You can view all of Geert-Jans work if you browse a few revisions back in Browse Source on the website for Events.module.
Regards, Ron.
I saw Geert-Jans work indeed. It is much better code than i could do, so that's why i just made these small fixes, hoping he will continue his good work
