hello,
I've installed my server new from windows xp NL to Windows 7 32bit DE.
the only problem is now i see no sensors in rfx charts.
not in the chartpages and not in the weather page. in setup weatherpage i can't select any sensors too.
the configuration in rfxcom are standing right (rfxchart adressed to 10 11 or 12)
sensors are also working and visible in homeseer.
to get the rfxchart-page to work I had to change some lines because in windows 7 DE there is the program file dir. different.
it is not called programs but programme.
I hope someone can help me.
gtz Ralph
no sensors in rfxcharts
Ralph
- b_weijenberg
Re: no sensors in rfxcharts
try this:
RFXCHARTS logging: By RFXCharts sampling (other modes are not supported)
Show on RFXCHARTS chart#: 2
- b_weijenberg
is the script PH_RFXCOM2.vben running every 2 minutes past the hour?
yes it is running 2min after every hour the same as before I changed to the new windows.
the problem is that I don't see any sensor.
grz ralph
grz ralph
Ralph
dow here I have the log file with the errors
02.12.2010 07:48:48 RFXCOM2 Error: Input Devices HouseCode InpDevHC doesn't contain a correct value.
02.12.2010 07:48:48 Info Wind Chill calculation skipped - Missing input sensor
02.12.2010 07:48:48 Info Dew Point calculation skipped - Missing input sensor
02.12.2010 07:48:48 Info Heat Index calculation skipped - Missing input sensor
02.12.2010 07:48:48 Error Error recording wind chill vlaue :N
02.12.2010 07:48:48 Error Error recording heat index vlaue :N
02.12.2010 07:48:48 Error Error recording dew point vlaue :N
02.12.2010 07:48:48 Error Scripting runtime error: System.Reflection.TargetInvocationException: Ein Aufrufziel hat einen Ausnahmefehler verursacht. ---> System.NullReferenceException: Die Objektvariable oder die With-Blockvariable wurde nicht festgelegt. bei Microsoft.VisualBasic.CompilerServices.Symbols.Container..ctor(Object Instance) bei Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateCall(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack, Boolean IgnoreReturn) bei scriptcode2.scriptcode2.Main(String pParms) --- Ende der internen Ausnahmestapelüberwachung --- bei System.RuntimeMethodHandle._InvokeMethodFast(Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bei System.RuntimeMethodHandle.InvokeMethodFast(Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeTypeHandle typeOwner) bei System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) bei System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) bei System.Reflection.MethodBase.Invoke(Object obj, Object[] parameters) bei Scheduler.VsaScriptHost.Invoke(String ModuleName, String MethodName, Object[] Arguments)
Ralph
- b_weijenberg
please contact support rfxcom.com !!
