I'm using the software developed by Kevin Lo and written in VB6 and located at:
http://x10-hk.com/store/download/PLCBUS ... ithOCX.zip
Any advice would be appreciated
Thanks
Moderator: Digit
Um that's kinda illegal to do here, the house we're setting this up in is brand new and the modules have been wired in by an electrician...so all done above board (I don't want to do anything that may void any insurance). I think we've ended up with around 3 lighting circuits and 3 power circuits, and I believe the cable used for power is a different thickness to the cable for lighting, so creating a mixed circuit may affect the circuit breakers and RCD's that are required here (however I'm far from being an expert on electrical installs). I will ask the electrician though if he can hook up a power socket on one of the light circuits for testing purposes, and if it works then I'm not sure what I'll need to do in the long term.by Digit » Thu Dec 16, 2010 8:50 am
That could very well be the problem!
If it's not too much work, try to get both on the same circuit and try again.
