Has anyone a good idea to put the jeenode + roomboard in a small housing/case?
I'm looking for a small/nice housing, so i can mount it on the wall.
Case/housing for jeenode with roomboard
Moderator: Mdamen
Re: Case/housing for jeenode with roomboard
I use a couple of these: http://www.dickbest.nl/webshop/index.ph ... ductId=742
Here you can see the size related to a JeeNode + Pressure Plug:
http://blog.hekkers.net/2010/05/05/jeen ... or-closed/
Thanks for your suggestion, but i like to mount it to the ceiling.
Its hard to get an empty box for the ceiling with WAF.
- ceil2.jpg (5.5 KiB) Viewed 3733 times
- ceil1.jpg (2.81 KiB) Viewed 3733 times
