Like to adapt named status Visonic doorsensors
Since a few days and some cleaning up my Homeseer setup, I see that the status of my doorsensors has changed to alert/normal instead of open/closed. Is there an easy way to change this back to open/closed (and showing again the right icons)?
- b_weijenberg
Re: Like to adapt named status Visonic doorsensors
modify the sensor on the RFXCOM security config page and change the text for alert/normal to open/closed
The only way to change this is to go through the RFXCOM configuration and modify the alert/normal status text.
DJ
DJ
Thanks for the quick help; it works now!
