i get an awfol lot of reconnection errors or to many charater errors.
are there rules to tune the polling time or other variables of the connection ?
31-1-2011 13:30:42 Error RFXCOM(ComTimer_Elapsed) IO #1 response took too long 192.168.10.201 , retry
31-1-2011 13:30:42 Info RFXCOM(reconnect) receiver #1 try to reconnect.
31-1-2011 13:30:43 Info RFXCOM(reconnect) receiver #2 try to reconnect.
31-1-2011 13:30:43 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238.jjj, retry
31-1-2011 13:30:47 Error RFXCOM(ComTimer_Elapsed) IO #1 response took too long 192.168.10.201 , retry
31-1-2011 13:30:48 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238jjj, retry
31-1-2011 13:30:48 Warning RFXCOM(ComTimer_Elapsed) IO #1 too many characters received 192.168.10.201 , retry
31-1-2011 13:30:49 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238.jjj, retry
31-1-2011 13:30:50 Error RFXCOM(ComTimer_Elapsed) IO #1 response took too long 192.168.10.201 , retry
31-1-2011 13:30:51 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238.jj, retry
31-1-2011 13:30:51 Error RFXCOM(ComTimer_Elapsed) IO #1 response took too long 192.168.10.201 , retry
31-1-2011 13:30:52 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238.jjj, retry
31-1-2011 13:30:52 Error RFXCOM(ComTimer_Elapsed) IO #1 response took too long 192.168.10.201 , retry
31-1-2011 13:30:53 Error RFXCOM(ComTimer_Elapsed) IO #0 response took too long 62.238.jjj, retry
tuning lan connections
- b_weijenberg
Re: tuning lan connections
Do you have a RFXio installed???
If not remove the IO devices from the RFXCOM Interfaces configuration.
no and the removal of the io devices works fine, no error messages anymore.
i now understand the need of i/o port configuration on the interface rfxlan in the rfxreceiver.
i cant find any rfxio information on the rfxcom website, with google some information.
not much fabricated or used.
thank you.
thank you.
