new KAKU products
Forum about Click On Click Off (KAKU), Home Easy and related hardware.
Jeroen Bartels
new KAKU products
Post by Jeroen Bartels »
Yesterday I was in the Gamma and noticed that there are some new switches available.
They have a new design (like the http://www.klikaanklikuit.nl/product_detail.asp?id=71)
They have new sets that are more expensive than the starter kits (mentionned above) but they have more memory places (6 instead of 3) but can only switch 1000 watts instead of 2300.
I was wondering if the new line of switches will still be rfxcom compatible and if the dimmers still have the DIM-level setting (e.g. set 40%)
Is it Home easy protocol or KAKU?
Anybody have experience with the new models? Or should I start buying old stock?
**Jeroen**
Jeroen Bartels
Re: new KAKU products
I went back to check the modeltypes:
Heavy switch 3500 Watt: ACD-3500
normal switch 1000 Watt: ACD-1000R
Dimmer 300 Watt: ACD-300R
New KAKU Dimmer; can the dim level be pre-setted by RFXCOM???
Any experience?
**Jeroen**
Rutger
Post by Rutger »
I bought a few weeks ago the seperate ACD-300 dimmer.
Yes they are dimmable is every % you want.
I think the "R" stand for Remote control.
The ACD-300R has a learn function, as I can see on the picture, and I think it's not different than the ACD-300 without remote control.
DJF3
Post by DJF3 »
So compatible with RFXCOM transmitters/receivers?
Rutger
Post by Rutger »
Yes
Return to “Click On Click Off & Home Easy”
