Jeenode+DS18B20+Homeseer
Moderator: Mdamen
As this is my first post I want to begin by saying "Hello" and a big "THANK YOU" to the entire community!
Just ordered my Jeenode+Jeelink and intend to use them mostly for reading temperature and control 1-2 relays.
For the temperature reading I want to use DS18B20 .
I've read about different sketches (4 digital inputs, 1 input+1output) used to integrate the Jeenodes with homeseer but could not find any references about using 1 wire temp sensors with Jeenode+Homeseer.
I've read that the maximum number of devices/jeenode in homeseer is 8, not a deal breaker as I can use 2 relays and 6 temp sensors, the problem is naming/creating this devices as all examples using arduiono+1-wire will auto detect the 1-wire devices. There is a work-around to individually name the DS18B20 in jeenode/homeseer? Can someone please help me with an example?
Unfortunately i kinda have a "gift" for making things more complicated that actually are, so hope that my "project description" will make sense to anyone willing to advice/help me.
Thank you!
Iulian
Thank you!
Iulian
You're right, no examples here with the combination of 1-Wire+JeeNode+HomeSeer.
I'll see if I can find some later this evening.
Here some pointers to get you going. A while ago I modified a small sketch for reading DS18x20 sensors that I found on the Arduino Playground:
This sketch belongs to this post: http://blog.hekkers.net/2010/08/07/addi ... mperature/
As you can see on the picture, I'm using a single 1-Wire bus to read the temperature of 3 sensors. More can be added though on that single bus!
That's what 1-Wire is about; you could also define multiple 1-Wire buses all with just a single sensor on it. Maybe that's easier to do. Also mind the difference of temperature calculation with DS18S20 and DS18B20!
If I were you I would start with trying out this code and rewriting it, cause what you'll probably need to do is map an id to a specific sensor with a specific 8-byte (64-bit) address. How? There are too many solutions (even without creating multiple 1-Wire buses as mentioned above); find the one that fits you best
Once you've managed that, the next step is some smart copy/pasting into the JeeNode for Homeseer sketches you can find over here.
And if you run into trouble, maybe we can help..
#include <OneWire.h>
/* DS18S20 Temperature chip i/o */
OneWire ds(10); // on pin 10
void setup(void) {
Serial.begin(9600);
void loop(void) {
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
char buf[20];
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//Serial.print("Read again.\n");
Serial.println("");
ds.reset_search();
delay(1000);
return;
Serial.print("Addr:");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] != 0x10) {
Serial.print("Device is not a DS18S20 family device.\n");
return;
// The DallasTemperature library can do all this work for you!
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
// Serial.print("SP=");
// Serial.print(present,HEX);
// Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
// Serial.print(data[i], HEX);
// Serial.print(" CRC=");
// Serial.println( OneWire::crc8( data, 8), HEX);
// erin
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
// ds18B20
//Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
//ds1820
Tc_100 = (TReading*100/2);
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
//sprintf(buf, "%c%d.%d\337C ",SignBit ? '-' : '+', Whole, Fract < 10 ? 0 : Fract);
Serial.print(" Temp=");
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.println(" grC");
//Serial.println();
Re: Jeenode+DS18B20+Homeseer
I want to thank you for help and prompt reply.
Unfortunately, after the joy of receiving my "toys" (Friday), now I'm on hold again as my USB-BUB is unable to upload sketches or power my Jeenode.( http://forum.jeelabs.net/node/88 )
Also Jean helped me to locate the rooms.pde he used with 1wire sensors:
jeelabs.net/projects/jeemon2010/reposit ... /rooms.pde
Hope to start some testing soon (another week of waiting
Homeseer Jeenode Thermostat
Waiting for my 1wire sensors and having my Jeenode up and running started to write a sketch for an independent Jeenode Thermostat with Homeseer integration.
Now, starting is one thing.... getting results..... a different ....
Project requirements:
- 2 thermostat modes: Heat & Cool;
-multiple set points controllable from Homeseer, or at least 2 set points: 17C and 25C (the project is for a greenhouse and this will be the temp. required for night and day);
- a 3C Differential on the thermostat;
- the thermostat should work on Jeenode booting, even if not connected to Homeseer (preferably on heat mode)
I've tried 2 paths:
1. Using condition rules:
-created 4 output devices(day heating, day cooling, night heating, night cooling);
-input devices: Light, Temp, Humidity;
-virtual output device (not mapped to a port on jeenode) - Set Point;
Results:
because condition rules will overwrite each other I've managed only to start the thermostat function, I was unable to find a way to stop the heat/cool when the desired temperature was reached. Maybe something I missing, tried multiple combination, but the last condition will overwrite results for the previous so the heatin/cooling function will stay either ON or OFF depending on the last condition. I even used 4 outputs just to reduce possibilities to overwrite the decisionrules, but no luck.
This is the decisionrules section: The setpoint is decided depending of the light level (day/night)Like this I was able to start all heating/cool function but no way to stop it.
Decided to change approach and make only a heating mode thermostat using decisionrules: no luck, did not succeed to turn the thermostat both ON an OFF .
2. Using as example this : http://www.ka1kjz.com/?p=797 , tried to add the thermostat to the homeseer_jeenode sketch in order to run as a loop and Homeseer will control only MODE and ON/OFF functions.
I've defined a DIFFERENTIAL of 3(degrees)
In the loop section added the following:
This section is for cooling.
What happens is that Homeseer is giving the following error
Error - Running script, script run or compile error in file: jeeNode.txt13:Type mismatch: 'CInt' in line 239 More info: Type mismatch: 'CInt' .
I consider that second method (loop thermostat) may work, but not sure if calling the right variables, what can I use instead of "payload.temp" and "payload.setpt" as I'm not sure this is the right approach ?
Any suggestions, advices , different approaches will be appreciated.
I hope I've made any sense, had a really long day of trial and loads of errors, so not quite sure that I'm still coherent.
lulu2607
I've tried 2 paths:
Results:
/ HEATING: LED1(dev0)&LED3(dev5); COOLING: LED2(dev1)&LED4(dev7)
// day heating
rules[0].numConditions = 3;
rules[0].numTrues = 3;
rules[0].numFalses = 3;
rules[0].conditions[0].device = 2; // if is day
rules[0].conditions[0].sign = LT;
rules[0].conditions[0].value = 45;
rules[0].resultsTrue[0].device = 0; // led1 heat
rules[0].resultsTrue[0].value = 1; //is on
rules[0].resultsFalse[0].device = 0; //led1 heat
rules[0].resultsFalse[0].value = 0; // is off
rules[0].conditions[1].device = 6; //and tstat on heating
rules[0].conditions[1].sign = EQ;
rules[0].conditions[1].value = 0;
rules[0].resultsTrue[1].device = 0; // led1 heat
rules[0].resultsTrue[1].value = 1; //is on
rules[0].resultsFalse[1].device = 0; //led1 heat
rules[0].resultsFalse[1].value = 0; // is off
rules[0].conditions[2].device = 4; // if temperature
rules[0].conditions[2].sign = LT;
rules[0].conditions[2].value = 22;
rules[0].resultsTrue[2].device = 0; // led1 heat
rules[0].resultsTrue[2].value = 1; //is on
rules[0].resultsFalse[2].device = 0; //led1 heat
rules[0].resultsFalse[2].value = 0; // is off
//day cooling
rules[1].numConditions = 3;
rules[1].numTrues = 3;
rules[1].numFalses = 3;
rules[1].conditions[0].device = 2; // if is day
rules[1].conditions[0].sign = LT;
rules[1].conditions[0].value = 45;
rules[1].resultsTrue[0].device = 1; // led2 cool
rules[1].resultsTrue[0].value = 1; //is on
rules[1].resultsFalse[0].device = 1; //led2 cool
rules[1].resultsFalse[0].value = 0; // is off
rules[1].conditions[1].device = 6; //and tstat on cooling
rules[1].conditions[1].sign = EQ;
rules[1].conditions[1].value = 1;
rules[1].resultsTrue[1].device = 1; // led2 cool
rules[1].resultsTrue[1].value = 1; //is on
rules[1].resultsFalse[1].device = 1; //led2 cool
rules[1].resultsFalse[1].value = 0; // is off
rules[1].conditions[2].device = 4; // if temperature
rules[1].conditions[2].sign = GT;
rules[1].conditions[2].value = 28;
rules[1].resultsTrue[2].device = 1; // led2 cool
rules[1].resultsTrue[2].value = 1; //is on
rules[1].resultsFalse[2].device = 1; //led2 cool
rules[1].resultsFalse[2].value = 0; // is off
//night cooling
rules[2].numConditions = 3;
rules[2].numTrues = 3;
rules[2].numFalses = 3;
rules[2].conditions[0].device = 2; // if is night
rules[2].conditions[0].sign = GE;
rules[2].conditions[0].value = 45;
rules[2].resultsTrue[0].device = 7; // led4 night cool
rules[2].resultsTrue[0].value = 1; //is on
rules[2].resultsFalse[0].device = 7; // led4 night cool
rules[2].resultsFalse[0].value = 0; // is off
rules[2].conditions[1].device = 6; //and tstat on cooling
rules[2].conditions[1].sign = EQ;
rules[2].conditions[1].value = 1;
rules[2].resultsTrue[1].device = 7; // led4 night cool
rules[2].resultsTrue[1].value = 1; //is on
rules[2].resultsFalse[1].device = 7; // led4 night cool
rules[2].resultsFalse[1].value = 0; // is off
rules[2].conditions[2].device = 4; // if temperature
rules[2].conditions[2].sign = GT;
rules[2].conditions[2].value = 19;
rules[2].resultsTrue[2].device = 7; // led4 night cool
rules[2].resultsTrue[2].value = 1; //is on
rules[2].resultsFalse[2].device = 7; //led4 night cool
rules[2].resultsFalse[2].value = 0; // is off
// night heating
rules[3].numConditions = 3;
rules[3].numTrues = 3;
rules[3].numFalses = 3;
rules[3].conditions[0].device = 2; // if is night
rules[3].conditions[0].sign = GE;
rules[3].conditions[0].value = 45;
rules[3].resultsTrue[0].device = 5; // led3 night heating
rules[3].resultsTrue[0].value = 1; //is on
rules[3].resultsFalse[0].device = 5; // led3 night heating
rules[3].resultsFalse[0].value = 0; // is off
rules[3].conditions[1].device = 6; //and tstat on heating
rules[3].conditions[1].sign = EQ;
rules[3].conditions[1].value = 0;
rules[3].resultsTrue[1].device = 5; // led3 night heating
rules[3].resultsTrue[1].value = 1; //is on
rules[3].resultsFalse[1].device = 5; // led3 night heating
rules[3].resultsFalse[1].value = 0; // is off
rules[3].conditions[2].device = 4; // if temperature
rules[3].conditions[2].sign = LT;
rules[3].conditions[2].value = 15;
rules[3].resultsTrue[2].device = 5; // led3 night heating
rules[3].resultsTrue[2].value = 1; //is on
rules[3].resultsFalse[2].device = 5; // led3 night heating
rules[3].resultsFalse[2].value = 0; // is off
// night heating OFF
rules[4].numConditions = 3;
rules[4].numTrues = 3;
rules[4].numFalses = 3;
rules[4].conditions[0].device = 2; // if is night
rules[4].conditions[0].sign = GE;
rules[4].conditions[0].value = 45;
rules[4].resultsTrue[0].device = 5; // led3 night heating
rules[4].resultsTrue[0].value = 1; //is on
rules[4].resultsFalse[0].device = 5; // led3 night heating
rules[4].resultsFalse[0].value = 0; // is off
rules[4].conditions[1].device = 6; //and tstat on heating
rules[4].conditions[1].sign = EQ;
rules[4].conditions[1].value = 0;
rules[4].resultsTrue[1].device = 5; // led3 night heating
rules[4].resultsTrue[1].value = 1; //is on
rules[4].resultsFalse[1].device = 5; // led3 night heating
rules[4].resultsFalse[1].value = 0; // is off
rules[4].conditions[2].device = 4; // if temperature
rules[4].conditions[2].sign = LT;
rules[4].conditions[2].value = 15;
rules[4].resultsTrue[2].device = 5; // led3 night heating
rules[4].resultsTrue[2].value = 1; //is on
rules[4].resultsFalse[2].device = 5; // led3 night heating
rules[4].resultsFalse[2].value = 0; // is off
if (payload.temp > payload.setpt) // come on at setpoint
led.digiWrite(1); // turn on GREEN (cooling)led
pir_ldr.digiWrite(0); // turn on RED(HEATING) led
if (payload.temp < payload.setpt - DIFFERENTIAL) // is temp at setpoint - differential?
pir_ldr.digiWrite(0); // turn off RED(HEATING) led
led.digiWrite(0); // turn off GREEN(COOLING) led
lulu2607
I think the easiest/quickest way to get results is to give me the complete sketch, so that I can upload it to one of my JeeNodes and have a look at what's going wrong. If you modified anything in the Homeseer script (jeenode.txt) send me that one too.
You can mail it to jeenode at hekkers dot net, I will have a look and report back what had to be changed to get it working.
Thanks!
Already emailed you the sketches. Let me know if you didn't receive them to try send them from another email account.
lulu2607
lulu2607
any News about this item?
i am also searching a good solution for my sensors.
i want to add a 1-wire ds18 temp sensor to my jeenode. (actually a arduino pro mini with jeenode sketch)
i was hoping to read more in this topic about it....
greetz,
Iwan
Iwan
IIRC, lulu2607 managed to read a DS18B20 sensor and get the result in Homeseer.
After that, I don't know.
But...reading a DS18B20 is not that hard; there are lots of examples that can be easily found!
is it possible to just copy past the code into the jeenode sketch to et it to work? I am not a programmer so it is not really my area of expertise.
is it possible to put the sketch (jeenode with ds18) online so i can see how it is done...if i know that, then i know how i can make the sketch working if i have just a ldr of just a pir connected to my arduino pro mini.
thanks alot
thanks alot
greetz,
Iwan
Iwan
Copy/Paste? Probably not. A JeeNode sketch will almost always use the RF transceiver to send the sensor values, so you will need to have a RF12 transceiver connected to your Arduino Pro; do you? And if not, what are you going to do with the values once you can read a DS18x20?
Another question is: what are you going to use on the receiving side? This all has a lot of impact on how the sketch will have to look like.
sorry, the complete info is this.
i have a jeelink (usb) connected to homeseer (and configured)
The arduino pro mini is on it's way and some rfm12b chips. I have the schematics on how to connect the rf12 to the arduino pro mini. AND i can connect the ds18 or other sensor to the arduino (with help of the jeenode schematic).
So i only need to have/make the sketch to get the ds12 to work. As i know that there are jeenodes that work with a ds18.
hope this makes it a bit more understandable what my situation is...sorry for the confusion.
greetz,
Iwan
Iwan
Thanks for the additional info.
One thing left... Do you realize "the" DS18 does not exist? It's either a DS18S20 or DS18B20. The DS1820 has been replaced by the software compatible DS18S20. The DS18B20 has 9-12 bit resolution, DS18S20 has a fixed 9 bit resolution. And both have a different family id (10 vs. 28, all of this IIRC) and need to be handled differently in software (=sketch) to calculate the right temperature.
If all this information is new to you, my advice would be to skip this whole exercise. Buy something Plug&Play or spend time learning the basics. It's either time or money, you know...
BTW, completely OT, but now that my memory starts working again... are you the same person that persuaded me to contact mister Nodo in January 2011 for some sort of cooperation? Of whom I have never heard 1 byte after a brief reply saying "I will contact you for a meeting", resulting in complete silence? But where I did read things like "those Jeenode guys will probably not be willing to share stuff with us" on the Nodo Google groups!?
<censored by global forum admin>
What's the story, what have I missed?
thanks for the info n the ds18x20 (family). I have a habbit of shortning names that leads to cunfusion sorry. I am taking time to learn this stuf....
About the nodo question. You are right. that was me. I do not know what happend. I think i just forgot completly (very busy with my own company). About the topic about " those jeenode guys......" i must of missed because i do not know about this topic.
What i do know is that the nodo project has a different perspective and direction. The want to combine a couple of things, but want to stick to basics. I would like to have a homeseer plugin, but that stalled a long while ago, because there are just a few that uses homeseer inside that group.
sorry for that, it was not my intension to forget.
greetz,
Iwan
Iwan
I just managed to create a test setup (the first one ever) with a Jeenode and 3x DS18B20 on one bus.
Do you have any influence on the order of the DS18B20's readout? The physical location on the breadboard doesn't change the order of readout.
ROM = 28 D8 E6 93 3 0 0 B0
Chip = DS18B20
Data = 1 17 1 4B 46 7F FF 9 10 8E CRC=8E
Temperature = 17.44 Celsius, 63.39 Fahrenheit
ROM = 28 4C BE 93 3 0 0 76
Chip = DS18B20
ROM = 28 82 A1 93 3 0 0 E9
Chip = DS18B20
Data = 1 19 1 4B 46 7F FF 7 10 EB CRC=EB
Temperature = 17.56 Celsius, 63.61 Fahrenheit
No more addresses.
