fietspomp javascript pronto irtrans vliegtuig
- Snelvuur
So, does anybody made some javascript snippet for the pronto so that you can directly trigger a signal on the irtrans? So instead of using homeseer for instance (saves a few miliseconds) since my zapping experience with homeseer in between just isn't fast enough..
p.s. yes strange topic, i got the dreadfull "your topic is too similar, i could not submit... \o/
Re: fietspomp javascript pronto irtrans vliegtuig
Eric,
No results yet with your search? Maybe I can help you out, if there's no alternative.
But I'll have to do this on an evening when I'm home alone, cause otherwise I would make everybody crazy here (except myself
- Snelvuur
Hmm no, i tried a post on irtrans and asked around but so far no luck. I mean all the codes are stored in the irtrans database through homeseer i believe so i dont have to enter them again. Because i was almost finished with the complete rework of the pronto interface and then i thought, if i use irtrans i dont have to aim
but since we still use the pronto in the living room (still much better then a ipad since you have hard buttons) i could just as well control the lights and such with it.
OK.
Guess what, the IRTrans is free tonight
Do you have any idea how HS controls the IRTrans? In my case I have a IRTranstray app running which I can send commands like:
Asnd upc,channelup
which means that the code that's stored in a upc.rem file somewhere, is sent to the IRTrans box by the tray app. Result: the upc box goes to the next channel.
Do you recognize this?
In that case, I think that I can get it running in let's say an hour or so.
Asnd upc,channelup
- Snelvuur
I think that works the same yes.. its i believe this one http://www.irtrans.de/download/Docs/IRT ... ace_EN.pdf
Asnd <remote>,<command>,[l<led>],[b<bus>],[m<mask>]
Asndr <remote>,<command>,[l<led>],[b<bus>],[m<mask>]
and similar, if its going to be tcp/ip i can always open up that port for you..
Well let's give it a try then
I'll have to wait till the kids are gone upstairs though ...
- Snelvuur
I still have 6 months to go, and then i face the same..
Eric, my congratulations!
I created a xcf with 1 activity that has this activity script:
It's quick&dirty, but it works. All you have to do is change the xx.xx.xx.xx to the IP address where the IRTransTray tool is running. Port 21000 is the standard (registered) IRTrans port.
I also added Prontoscript to 2 Hard Buttons (CH+, CH-). Code for CH+ button:
Here you have to change "upc" to whatever device you want to control (check your rem files) and change "channelup" to the command you want to be sent. I will send you the XCF file I used for testing. You can remove all the System.print statements when you've got it working, they were only meant for the debug panel. And remember to change the Wifi settings to yours.
Have fun
function TCPSend(dvc,cmd)
var socket = new TCPSocket(false);
var result = "";
socket.onConnect = function()
System.print("Connected.");
var str = "";
str = "ASCIAsnd "+dvc+","+cmd+"\r";
System.print(str);
socket.write(str);
socket.onData = function()
result = socket.read(5000,1000);
socket.onIOError = function(e)
System.print("IO Error.");
if(socket.connected == false)
socket.connect('xx.xx.xx.xx', 21000, 3000);
socket.Free;
TCPSend("upc","channelup");
Have fun
- Snelvuur
Alexander: no you are correct, i will be daddy
so i am actually trying to finish stuff now, because then i dont have the time for it (well you still can but you rather not do it then)
- Snelvuur
First test do give me a massive increase of zapping. Its almost as if i have the normal remote. I could not get this through homeseer in between. Only problem now is that after a certain amount of zapping , the irtrans tray client refuses to work anymore. I have top stop/start it and then its ok again (yes i also turned of firewall just in case but no difference)
- Snelvuur
And we have a winner:
This one also closes the statements ad closes the calls correctly, so all bugs are out of this one. Tested it like a million times by pressing buttons and it was still going strong.
var IPAddress="192.168.1.50";
var Port="21000";
var Timeout="20";
var str = "";
var receivedText = "";
function reInitSocket()
socket = new TCPSocket();
socket.onConnect = onConnect;
socket.onData = onData;
socket.onClose = onClose;
socket.onIOError = onIOError;
socket.connect(IPAddress, Port, Timeout);
function onTimeout()
reInitSocket();
function onConnect(){
if ( socket ) { socket.write( str ); }
else {System.print("onConnect: No Socket"); }
function onData(){
System.print("Ondata.");
receivedText = socket.read(5000,1000);
socket.close();
socket = null;
function onClose(){
System.print("onClose Event: Socket closed by IRtrans");
socket = null;
function onIOError(e){
System.print("Socket error, closing socket");
socket.close(); socket = null;
function TCPSend(dvc,cmd){
reInitSocket();
