circling x10 off command
labium
Post by labium »
when i push off in homeseer pro a x10 device on transmitter 2 the devices keeps going on and off with an interval of a minute. it stops when i disconnect the homeseer from the rfxmitter and use rfmitter to send the off signal.
i have 2 transmitters and 2 receivers in the homeseer and a cm15pro not on the location where this happens it , there a have a tm13 to receive the rfxcom x 10 signals.
what could be the problem.
labium
b_weijenberg
Re: circling x10 off command
Post by b_weijenberg »
do you have an Event in HS that is activated on this command?
Or a macro in the CM15?
Check the HS log what happens.
