Philips Homerun Robot vacuum cleaner FC9910
Forum about Domotica related gadget like Pocketpc, UMPC, Smartphones, Ipad Etc
Moderator: TANE
Philips Robot vacuum cleaner FC9910
Philips can not stay behind!
Energieverbruik in stand-by 1W, much better then others like the Roomba!
Afmetingen 345 x 104 mm, Like 20mm higher the Roomba :?
http://hubpages.com/hub/Philips-FC9910-HomeRun-Review
For 599 euro
and for 329 euro with ING Rentepunten :)
Looks like a nice and solid Robotcleaner, but not much specs on the site.
shop.philips.com/store?Action=DisplayPr ... =226826200
Kleur Metallic oestergrijs
Prestaties
Batterijtype 14,8 V li-ion/2200 mAh
Reinigingssnelheid 40 m²/u
Navigatiemethode Systematisch kaartsysteem
Sensoren Camera, gyroscoop, infrarood
Geluidsniveau (Lc IEC) 70 dB
Oplaadtijd 3 uur
Batterijvoltage 14,8 V
Looptijd 100 minuut/minuten
Filtering
Stofinhoud 0,6 l
Bruikbaarheid
Reinigingsmodi Automatisch, spot, climb, carpet
Vloertypen Parket, laminaat, tegels, tapijt
Programmeren 24 uurstimer
Opladen Automatische terugkeer naar het basisstation
Speciale functies Trapdetectie
Drempelmodus 15 mm
Duurzaamheid
Verpakking > 90% gerecycled materiaal
Gebruiksaanwijzing 100% gerecycled papier
Energieverbruik in stand-by 1 W much better then others like the Roomba!
Afmetingen en gewicht
Afmetingen 345 x 104 mm Like 20mm higher the Roomba!
Gewicht van het product 4,1 kg
Re: Philips Homerun Robot vacuum cleaner FC9910
Nice clips.
It makes clear that Philips is still far behind in software.
Roomba +1 here
Agree, same conclusion here :)
SolidReason
Post by SolidReason »
This Robot Vacuum cleaner was reviewed on Hardware Info last month (in Dutch though). In this review, the cleaner is compared against competitors like the Samsung’s Navibot SR8855 and Roomba 555, the FC9910 ranked pretty much under par.
BTW, the Vacuum coverage test in that same review is great to watch and clearly shows the different cleaning strategies.
Return to “Gadgets Forum”
