Software for recording Foscam video
Moderator: Esteban
bing
Post by bing »
Have two IP cameras from Foscam. Used the standard mail and FTP functions. Now, however, wanted to record moving images. In the past, I used gotcha, perfect program, but does not support IP camera `s.
I try Webcam xp but it takes 100% CPU time.
What program do you use?
Verkenner
Re: ip-camera software
Post by Verkenner »
I use the Synology surveillance software.
It's very nice software delivered with the DS211J-NAS.
With motion recording. Works great.
And watch this±
http://www.gadgetvictims.com/2009/08/th ... am-ip.html
Best regards, Verkenner
Bastiaan
Post by Bastiaan »
phoenixb
Post by phoenixb »
Or http://www.pysoft.com/ActiveWebCamMainpage.htm
good software for pan/tilt/zoom op cams.
__________________
Henk_J
Post by Henk_J »
I use VLC player with homeseer to record video streams from a few Foscam camera's at the moment movement is detected. It's free, easy to use and you can record from several cams at the same time. If somebody is interested in the script I can post it here.
bing
Post by bing »
Henk_J wrote:I use VLC player with homeseer to record video streams from a few Foscam camera's at the moment movement is detected. It's free, easy to use and you can record from several cams at the same time. If somebody is interested in the script I can post it here.
I will try VLC player, the script is for homeseer?
Henk_J
Post by Henk_J »
I just use a windows bat file which is triggered within HS after movement is detected. I will post it somewhere in the coming days for you.
Henk_J
Re: Software for recording Foscam video
Post by Henk_J »
This is the .bat file executed after movement, I use separate bat files for separate camera's.
Install vlc player first. You can change the recording time by modifying the time parameter. Last command line renames the video output file.
cd C:\Program Files\VideoLAN\VLC
vlc "http://ip-addr:portnr/videostream.asf?user=username&pwd=password" --sout="#duplicate{dst=std{access=file,mux=asf,dst='C:\camera\voordeur.asf'},dst=nodisplay}" --run-time=15 --quiet vlc://quit
cd c:\camera
ren voordeur.asf "Voordeur_%date:~0,2%-%date:~3,2%-%date:~6,4%_%time:~0,2%_%time:~3,2%_%time:~6,5%.asf"
bing
Post by bing »
Henk_J wrote:This is the .bat file executed after movement, I use separate bat files for separate camera's.
cd c:\camera
Thanks!!
