Hi guys,
I'm a bit new to x10 world and completly lost !
I hope this is the good place to post my question.
So here is my setup and what i want to acheive :
- I have a wall light in which i have integrated a LW12 module, I have forgoten the switch part of it as the wall light doesn't have one, schema is basicaly in line : Neutral --> Lamp --> LW12 --> Live
This has been setup with adress C1.
When controling it from ActiveHome Pro with a CM15 I have no problem turning it on or off or dim, so far so good
- I have in the other part of the same room the place where i want to have my switch for this first light (and a second coming later on in the corridor exiting this room put it's not my concern right now ), the wall cable coming here are 1 Neutral and 1 Live cables, that's it.
So i have bought a IMX10 with 4 programmable address :
- one to command the existing LW12
- one for the future light in the corridor
- 2 will never be used and stay insulated behind the switch.
I have also bought a double retractive switch (I guess it's how it is called : twice a button that needs to be pushed at the same place either to switch on or off and that come back to it's place when released).
Wall's Neutral and Live are plugged to the IMX10.
IMX10's cable (neutral and first adress) is plugged to the first button of the switch.
IMX10's first adress has been configured to C1 to be aligned with my LW12.
I'm not configuring options like dimming for the moment, it's not my priority.
Now i have a "strange" behavior :
- if the LW12 is on and i push my switch it's turned off : OK
- if the LW12 is off and i push my switch it's briefly turned on then off again, it stays on as long as keep pushing the button but as soon as i release it goes off again : KO.
With Activehome Pro I have looked at the commands passing on the C1 address and when i push the button briefly and release it the imx10 send "C1 ON" and "C1 OFF" just after that.
I thought that IMX10 would be able to deal with retractive switch but it seems that if I want it to work i have to put a standard "rocker" switch to have the same behavior than when i keep the button pushed ??
I guess i don't understand this part of the IMX10 documentation :
Result
• ON/OFF function available for all inputs.
• Other inputs are automatically given consecutive addresses.
Input Address Sending* Operation
Brown B03 ON/OFF Send ON* or OFF* commands
Red B04 ON/OFF Send ON* or OFF* commands
Orange B05 ON/OFF Send ON* or OFF* commands
Yellow B06 ON/OFF Send ON* or OFF* commands
* Depends on the status of the switch actuator or address to be controlled
(toggle mode).
And especialy the (*) part : what is a switch actuator, what does "toggle mode" means in this context ?
Any help would highly be appreciated,
Tom.
P.S. : sorry for my english, it is not my first language.
P.P.S. : another thought:
You can find the userguide here , from "product download" : http://www.eurox10.com/Product/Micromod ... /IMX10.htm
I haven't found a part about implicitly choosing standard or push switch, only one reference or two to this "toggle" thing.
Do you think it may come from the "receiver" LW12 that is a one way module and won't give its current status to the IMX10 ?
Maybe the IMX10 needs the current status of the receiver (that could be switch locally or via ActiveHome) to no what the command to send to change state is ?
Problem with IMX10 and LW12
- Cablagex10.png (5.23 KiB) Viewed 3222 times
Re: Problem with IMX10 and LW12
I have resolved my problem by folowwing step 3.2. (on/off + dim/bright) of the install instead of 3.1. (simple on/off).
