What is the status of Z-Wave support?
I know that there is basic support for power switches, because I can't get some appliances to work.
What would I need to do to get more Z-Wave appliances to work? Could somebody point me in the correct way.
Kind regards,
John
Status of Z-Wave support
Moderator: RDNZL
- RDNZL
Re: Status of Z-Wave support
Which flavor are you using, the openzwave wrapper one, or the native zwave code?
Which kind of devices brand/model do you have problems with?
Which z-wave stick are you using, which firmware version?
What are the problems exactly, maybe some log output would help too.
Can you see the devices in the z-wave commander?
Please post your response here, or open a topic on the support forum on domotiga.nl, if you want to send more private info use the contact page.
Regards, Ron.
- Starting Member
Ron,
I tried both the ways. The openzwave and the native zwave code.
The stick I'm using. Aeon-Labs USB Z-Stick with the newest firmware.
I have the following hardware with issues.
Everspring Z-Wave Temperatuur en Vochtigheidsensor
Battery opperated, but never responds to domotiga.
Everspring Z-Wave Tussenstekker Schakelaar met Energiemeting
Switching works, but reading out the powerusage doesn't work.
Express Controls EZ Motion 3 in 1 Multisensor
DANFOSS Living Connect RA
I know that support of this product is even for homeseer difficult.
This is an overview of the zwave commander running on openzwave. As you can see the devices are available in the zwave commander, but they have the status "Unknown (21)"
A copy of the logfile is attached.
http://image.jolite.nl/2011-09-12-OZW_Log.txt
What do you like best. Use the forum on domotiga.nl or this forum? I don't mind.
Kind regards,
John
Kind regards,
John
