I am trying to interface the infared poort for a Landis & Gyr type ZCF 120 ABd
Anybody got his working ?
I made a disign that works with Realterm but meter is not responding to the /? CR LF request.
The diagram for the interface included
IEC1107 Infrared interface
- IEC1107 IR INTERFACE.pdf
- Rev 1.2 IEC 1107 interface RS232 to infrared
- (25.32 KiB) Downloaded 593 times
Re: IEC1107 Infrared interface
Are you sure, i need to send this "/?!"
its a other brand, but internal most iare the same
check also:
http://www.bwired.nl/weblog.asp?id=429
check also:
Hi Bwired,
Yes i think i have to send /?! cr lf
The datasheet for this type of meter = EN 62056-21 protocol is the same as IEC1107
In the attachment a explanation of the protocol and how it works
You have to send the request and get a reply this will tell you the id for the meter and the baudrate for the datatransmision.
The next thing is to send a ACK with the requested baudrate and you receive all the data from the meter.
- IEC 1107 62056-21 Specification'.rar
- Protocol 62056 or IEC1107
- (165.66 KiB) Downloaded 606 times
