My first "try" thing is done at the moment. Still needs lots of more fucntions and i can still do more with it but for the moment it will have to do
Give a call to : +31878709545 then you get a lovely female voice (english) with some options. If you do happen to leave a message you can find it back at:
http://home.rfje.org/calls/
Last 3 numbers are "xxx" to keep some privacy for people. It updates every 5 min. So if it does not say how long the call was its because it still needs to update.
p.s. if it didn't mask the number , then i need to tweak more since problems can occur (otherwise just dial without number id)
