Hi
I have a HE3202 (on/off power plug) that behaves in a weird way.
I paired it with domotiga software by making it learn ARC code "B4", and I can succcesfully switch it on/off using that code.
However, I also have a remote control, HE200; when I used the remote control by pressing On/unit2 (which sends a A2 code), the HE302 responds to that, although it should only answer to B4 code, not A2! even more, it also answers to A1!
Any idea what is going on?
Thanks
k
weird HE302 behavior
- b_weijenberg
Re: weird HE302 behavior
Did you reset the HE302 to remove all remotes from this unit?
well spotted.... that was the issue,
old remotes controlling the unit,
Thanks for your hep!
