does annyone knows how i can update HCB firmware 1.0 to 1.6
when i tried to update to 1.6 i get an error
Thanks
Firmware update HCB
Re: Firmware update HCB
Hi Marank08,
Maybe it's a good thing to tell a bit more, cause now the 1st question that you'll get will be: "what error ?"
Other members can't help you this way.
the error is:
http error in http eval of config_upgrade_file.pl: Global symbol "$substr" requires explicit package name at (eval 16049) line 135, line 193. syntax error at (eval 16049) line 135, near "$substr("
i get this error when i try to load this file: firmware-eh_1.6.0-1026
Gr
the error is:
Gr
- Starting Member
Hi Marank08,
Did you succeeded in installing the firmware, if not I have still the previous version HCB_firmware_eh_1.6.0_1025.zip, maybe this one works fine.
does annyone knows how i can update HCB 1.2.258 to -eh_1.6.0-1026.hcb
when i tried to update to 1.6 i get next error: Fout: het upgrade pakket heeft een ongeldig formaat. Controleer of u het juiste bestand heeft en probeer opnieuw (package.xml parse error)
Thanks
Thanks
Upgrading first to 1.4 is required and finally to 1.6 .. so try to find HCB 1.4 maybe marmitek ? Henk
Has anyone saved 1.6.0-1026.hcb? I can't find it these days anymore.
