Energy graphs in m?
Moderator: RDNZL
marunga
Energy graphs in m?
Post by marunga »
After creating and deleting a lot of graphs, all I can get is m as units (Y axle). Not Amps or Watts . I'm using advanced graphs (with simple graphs the result is the same). Also, in Graph Data, the Operation field does not change the result (I've read almost all posts on this forum regarding graphs in Domotiga and did not found a solution).
Any suggestion ?
thanksin advance,
regards,
m
RDNZL
Re: Energy graphs in m?
Post by RDNZL »
Sorry I completely missed this post (sigh, e-mail notifications don't always work on this forum)
Did you get any further yet? If not canyou mail a screenshot to see whats the problem?
I know there is a bug that the DS value is empty upon opening an existing graph, will look into that,
Regards, Ron.
marunga
Post by marunga »
Here is an example:
RDNZL
Post by RDNZL »
Are you sure you set the data-source type of the device(s) to "GAUGE" on the graph tab of the device(s)?
I have seen these milli notations before when a wrong data-source type was selected.
Regards, Ron.
marunga
Post by marunga »
Thanks, changing to Gauge resolved the issue.
regards,
m
Return to “DomotiGa Forum”
