Düwi spare parts?
slarti
Düwi spare parts?
Post by slarti »
Does anyone know where to get new support rings (the part in the picture) for Düwi modules? I have a few of them, and a couple of those are somehow smaller than the others, because the rocker (everluxe) comes loose really easily.
Mdamen
Re: Düwi spare parts?
Post by Mdamen »
You might want to ask TANE (from hashop.nl)...
Akatar
Post by Akatar »
the production was wrong, and no, you won't get new ones/.
i have the same, my last bought dimmers are lying in a box useless
Phaeton
Post by Phaeton »
You dan fix this!
Put a piece of ducktape over both holes.
The flipper will work and wont fall off. I had the same, as for allmost everything ducktape saves the day! ;-)
Akatar
Post by Akatar »
that sounds great for secondhand stuff, but it's dissapointing to make new duwi dimmers work as it should with ductape!
Phaeton
Post by Phaeton »
True, in fact... I used it for 2nd hand stuff. But i also read duwi replaces these plates under warranty? Maybe you can try it at the reseller?
slarti
Re:
Post by slarti »
Phaeton wrote:You dan fix this!
Thanks! This actually works pretty well :lol:. Since I only had two faulty ones from eight, I think I'll settle for this fix.
btienhoven
Post by btienhoven »
I had the same problem, Tane send me a manual to fix the problem by cutting small parts of the plastic covers which are included.
This works fine but takes a lot of time if you have to do a lot of switches.
So I let cut selfadhesive stickers complete with holes. This works perfect, and is easy to apply, let a few hrs on before attachting the paddle.
If you send me an email info@optimaalgemak.nl of send me a PB I can send you some as well.
Duwi selfadhesive pre-cut
Re:
Phaeton wrote:True, in fact... I used it for 2nd hand stuff. But i also read duwi replaces these plates under warranty? Maybe you can try it at the reseller?
There is no solution from Duwi for this problem.
All the new modules have still the same problem.
The workaround works well. this will cost you few minutes.
Other option is go for the Trend Line. this one will fit better.
martinisoft
Post by martinisoft »
Is this still an issue?
A friend of mine has asked me to help him choosing the right domotica products for his new home, and I don't want to point him in the direction of Düwi and/or Zwave.me when this issue still persists.
A few modules I purchased myself not to long ago have this issue and I find it really irritating, and rather ridiculous that Düwi is not doing anything about it.
thanks…
Martijn.
martinisoft
Anyone who can tell me if this issue still persists?
Hessel
Post by Hessel »
Does this problem only apply for dimmers or also for the zwave.me Duwi Everluxe switches?
My electrician is trying to figure out how to put pearl-white paddles on the BJ variant of the Zwave.me switches but will probably not succeed (according to other posts by Tane we need paint to do just that :wink: )
So for now it seems we are back to Duwi Everluxe. We only need four dimmers so a workaround is not to much hazzle. If we need workaround for all switches to, we need to rethink.
appreciate your replies
Phaeton
Post by Phaeton »
I have this problem with all duwi devices. Dimmer and switch. The tape solution works though. Quite good actually
groeten,
Hessel
Post by Hessel »
Thanks for the reply. Does anyone have experience with the other option mentioned by Tane. Using Trendline because these paddles have a better fit?
An out of the box solution seems better than a duct tape solution
Return to “Z-Wave Forum”
