I like to add the Plugwise chart to the Homeseer HSTouch screen.
URL that i can use is.
http://user:pass@localhost:8080/pwgraph ... 0793926718
How can i make this work every day since the day is in the url?
Plugwise Chart
Plugwise Chart
Re: Plugwise Chart
don't include from= and to=, the default is today.
(see page 25 of Plugwise_Source_Template_Engine.pdf)
Re: Plugwise Chart
How to select the appliance u want to view?
Re: Plugwise Chart
RTFM? It's all in the Plugwise_Source_Template_Engine.pdf, see page 25.
appids=ids (list of comma separated appliance ids for which to show the graph), default all appliances
grpids=ids (list of comma separated group ids for which to show the graph), default all appliances
rmids=ids (list of command separated room ids for which to show the graph), default all appliances.
Re: Plugwise Chart
Thank you...
Works great in HST.
User:Pass@ url line will not work in IE because of the security issue.
For testing you can use Firefox
Works great in HST.
Re: Plugwise Chart
new challenge.
I like to display the month production of my PV system.
I'm using this url to build up the charts.
http://user:password@192.168.1.100:8080 ... interval=d
This is working fine when manually entered the date
how can i make it to display the current month.
Fallowing url line will not work in HST
http://user:password@192.168.1.100:8080 ... C118&from=[$DATE=yyyy-mm]-01&to=[$DATE=yyyy-mm]-31&interval=d
Re: Plugwise Chart
The links don't work.
B.R. Wim
B.R. Wim
- Jeroen Bartels
Re: Plugwise Chart
Of course !!
