Preset Dim function on HE108 with RFXCOM
- Starting Member
I have a couple of areas where my RXCOM signal was not getting reliably to so I am thinking about adding an RF extender. If an HE108 gets two on signals then it will go into dim cycle mode, is the same true if I send a pre-set dim level from RFXCOM and that is then transmitted by potentially twice to the switch. When I try send repeated presets from RFXCOM I do not go into the Dim cycle. Steve
- b_weijenberg
Re: Preset Dim function on HE108 with RFXCOM
Sending 2 preset dim command will not set the module into a dim cycle.
To avoid problems with the 2 ON commands you can better use a set level 16 instead of an ON command. But this will only operate on a lamp module. An appliance module cannot be controlled using a set dim level command.
