New ELV MAX! Software 1.3.5 available
Moderator: jrkalf
Relaase Notes see max-portal.elv.de/downloads/MAX_1-3-5_R ... es_ELV.htm
Re: New ELV MAX! Software 1.3.5 available
Thanks !
Troubles installing the new software and firmware.
After installing it does not see some devices.
No connection with devices.
Spend some hours but could not find the problem/solution.
Still have to find out why it does not work.
Some sleep............
Best regards, Verkenner
Re: New ELV MAX! Software 1.3.5 is %$#@&!
Release 1.3.5 does not work here.
After installing the software (on the PC) and firmware (on the cube) it does not see the devices.
I have the solution to these problems.
Let the cube max application running in the background, and in the ini file set the port number to 62910.
For me, everything works perfectly now!
Yes, the port no. has changed from 80 to 62910. See release notes in german language max-portal.elv.de/downloads/MAX_1-3-5_R ... es_ELV.htm
- Snelvuur
lazy me wanted to google translate, and its just 1 big picture. even the manual is in dutch too, why not release notes in dutch/english too? O well, i'll let some other people check it out first before going over board
