Is it possible to add IR leds inside an existing dome camera?
Don't want to add separate IR leds unless these are available in a very compact formfactor (maybe a tiny strip?)
Add IR leds to existing dome camera?
Moderator: Esteban
- IMG_3784.jpg (24.36 KiB) Viewed 13600 times
- IMG_3785.jpg (20.53 KiB) Viewed 13600 times
Re: Add IR leds to existing dome camera?
DJ,
It's probably possible to hack some LEDs inside the camera. But if you add IR LEDs inside the dome you run the risk of them creating reflections in the dome showing up in your image and messing it up.
Correct, i have try this but to much reflections.DJF3 wrote:DJ,It's probably possible to hack some LEDs inside the camera. But if you add IR LEDs inside the dome you run the risk of them creating reflections in the dome showing up in your image and messing it up.
- Antoon
Any suggestions for small IR illuminators?
(preference: small strip that I can mount on the ceiling?)
- Fantic
With these you can surround the dome at any angle:
http://www.ebay.com/itm/5pcs-1W-Infrare ... 35bac6a56f
Kinda build your own strip.
Regards, Maarten.
Yeah, maybe that's the fastest way
Thanks for the tip..
