According to the manual, there a number of versions available, version 1.4 to 1.8.
Has anyone figured out what the difference is between these versions?
Which version is currently available in the supply chain?
Rg
Marck
Fibaro FGD-211 Dimmer versions
Re: Fibaro FGD-211 Dimmer versions
Tane, do you maybe know the answer to this one, given that you are one of the suppliers?
Tried, to register to the Fibaro forum, but no success thus far.
Rg
Marck
Rg
Marck
Very interested in this too since I have problems with some of my dimmers.
The firmware changes are all minore.
I have no info about the changes. I will ask Fibaro about this.
The latest dimmer Firmware is form 25/9/2012 this what i have in stock.
You can change lot of settings in the options of Fibaro. Maybe this can solve your problem?
What er the problem magmil?
Thanks for your reply. Is that latest version 25/09/2012, also version 1.8?
Not sure about that. Maybe even newer.
I have to install before I can see that.
Fibaro only shows the production date. 25/9/2012 is less than 4 weeks.
Most of my fgd211 works well but I have to problems:TANE wrote: What er the problem magmil?
8 50w gu10 halogen - sometimes flickers. Sometimes impossible to shut off, have to reset the fuse.
12 Philips 7.5W ledspotsmylamplights.com/ledino-by-philips-5792 ... 44816.html - sometimes flickers a bit. Always starts at max and is not possible to dim or shut off for appr. one minute.
Both have neutral lead and I have tried some different settings for parameter 20 (but not all).
Hi Tane, do you have any idea what I should try for my problems with FGD-211?
