SMS - Android - HomeSeer
I`m not sure how to explain but i have the following wish
I`m using a Android phone and would like to perform HomeSeer actions when i recieve a message from a given contact.
Re: SMS - Android - HomeSeer
Install tenHsServer (tenholder.net/tenWare2/tenHsServer/defa ... fault.aspx) in Homeseer.
Use the program "Tasker" on your Android phone and set up an event triggered by the SMS from a specific sender, that starts an action to send a http request (request a web page) to tenHsServertenHsServer is a single web page that processes requests specified in the URL that loads it, and displays a page (returns html that contains the result of request)
** Maurice **
Do you mean the tasker app that is costing €4.49 ? Are there any freeware alternatives ?
There's nothing like Tasker ...raymonvdm wrote:Do you mean the tasker app that is costing €4.49 ? Are there any freeware alternatives ?
Believe me, it's worth every penny !
Besides, you can download a trial via the dev homepage which gives you insight in what you want to do.
*edit* webpage for reference: http://tasker.dinglisch.net/
I`m trying to use AutomatIT and tenHsServer and although is should work it is not working yet.
When i open the url to run the event from a browser using thenHsServer is dropped because i`m not logged in using HomeSeer authentication (I want HomeSeer to denied al request until login)
Is there anyway to bypass this for the tenHsServer ?
Correct me if I'm wrong, but as far as I can tell it is not possible to trigger an event using tenHsServer ?mo046 wrote:Install tenHsServer (tenholder.net/tenWare2/tenHsServer/defa ... fault.aspx) in Homeseer.Use the program "Tasker" on your Android phone and set up an event triggered by the SMS from a specific sender, that starts an action to send a http request (request a web page) to tenHsServertenHsServer is a single web page that processes requests specified in the URL that loads it, and displays a page (returns html that contains the result of request)
Your wish i my command:
From the manual
RunEvent
f=RunEvent
d=EventName
Example: ?t=12&f=RunEvent&d=LeavingHouse
From the manual
RunEvent
f=RunEvent
d=EventName
Sorry, only looked at the overview html page
Today i took another shot on this plugin but is it not working as i want.
When my phone is unlocked and someone sends me a sms. The browser opens and the TenHSserver is responding and the event is run. But i need to disable login for local network on homeseer. And my phone needs to be unlocked ( this is not a normal situation)
The next step is to take a different approach. I now want to do the next thing
- Phone is recieving a sms (works)
- AutomateIT app on the phone is configured to send a new sms on reception of the first sms (works even if the phone is locked)
- The second sms is directed to my HomeSeer Nokia 6230 (works)
- The sms is read by HomeSeer en the needed event is run (not working)
I`m trying to get this going using the following plugin. I`m not sure when this plugin was written and for witch HS version
