New Source 2.23 (20130301.0) release!
Reinder
Post by Reinder »
An updated version of Source 2.23 (20130301.0) has been released. Please use the update button, or download the setup http://www.myplugwise.com to update your current version of Source.
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report.
You can find it in the bottom right of the blue title bar.
Plugwise Source 2.23 Release 20130301
New:
- Features can be enabled by separate feature license keys
- Reports: Production as negative values can be enabled under Settings->Program
- New icons for main meter, gas meter and water meter
- Pro: Support for ModBus gas and water meters
Fixes:
- Should work correctly on Windows 8 (Desktop)
- Reports: Several issues with charts have been solved
- Reports: In some cases, consumption tariff was used where production tariff should be used
- Reports: Different scaling for with or without comparison
Known issues:
- No support for Plugwise Stretch (Plugwise Smile is supported)
- German and Greek updates pending
- French translation outdated
pvgent
Re: New Source 2.23 (20130301.0) release!
Post by pvgent »
I installed the update and got a message that my license doesn't support more than 25 modules and that i have to contact Plugwise.
I have a total of 39 modules.
On the Plugwise website i can't find any information about licenses.
Seems like the extended script license, at first you could buy it for about 20 euro's and now you have to buy a Pro license.
WHB
Post by WHB »
Just installed it and it fixes the problem that Source 2.22 had; not finding the Stick on my Windows XP domotica thin client. :)
I have 32 modules, no special license, and did not see the licensing message.
Akatar
Post by Akatar »
i did the update, i recieved the same message (no licence for more then 25 call support, bij programs it reads.. 25 to 250 nodes.
few seconds later it crashed.
couldn,t start the source again, so went back to 2.22
RDNZL
Post by RDNZL »
I hope for the source/plugwise users who invested a lot of money buying plugs that this due to a bug...
Every time I read these kind of experiences with Plugwise the longer the list gets...
1) stealing data from users without telling them
2) when confronted with it remove the users right for updates if a user don't want to share his data
3) grab millions euros subsidies (which we all pay for) to join all kinds of environmental projects
4) and now this...
Regards, Ron.
Akatar
Post by Akatar »
zal zeker een bug zijn??
ik heb multiple licence versie met meer dan 1 stick in gebruik, dan is 25 nodes wel heel karig :)
vanisher
Post by vanisher »
Is there an alternative already?
rovinge
Post by rovinge »
I will wait with an update to 2.23 until this is clear on what this maximum number of modules is...
I am using about 40+ circles, 10 senses + switches, so I hope they clear this limit (or that there will be no limit at all)
R
Darwusch
Post by Darwusch »
After the update to 2.23 and a restart of the PC on which it runs, I get the following error:
object reference not set to an instance of an object
And then Source is closing, won't run anymore.
Now I can only view my data when I run PlugwiseServer.exe.
Also a restore of my backups didn't help.
I also tried running it with admin rights, no difference.
Tried going back to 2.22 but it can not recognize the updated database anymore, because 2.23 updated it.
Fix this a.s.a.p. please!
Akatar
Post by Akatar »
i had the same
started backup & restore, chose the last version... and up and running
Darwusch
Post by Darwusch »
Another bug, but this has been present for a long time and not since version 2.23.
When I use scripting to ask the totals of a plug since a given date, it only gives correct data of plugs which are consuming.
The plug which measures my solar panels and which has been set to produce, only shows the costs correctly. The production and CO2 are always zero:
Name 			 kWh 	 Euro    kgCO2
Koelkast 		0,65 	0,13 	0,37
Zonnepanelen   0,00 	0,14 	0,00
In the source it showed correct data.
Rutger
Post by Rutger »
I don't see any decimal values of Watt anymore. My wasmachine is now using 1 watt all the time when it's turned of. In the previous version it was 0.4 or 0.7 Watt.
My PC is using 17, 18 or 19 Watt continue, instead of 17.8, 18.5, etc.
On the webserver the Gas usage has still the W(att) symbol instead of m³. The used gas amount is counted together with the energymeter, which is incorrect.
Post by Harry »
i have the same problem as rutger,....and so not happy whith al that licening.
is there ever a change we get new functionalety in future update's
unless we have to pay for it?
DJF3
Post by DJF3 »
OUCH.. just upgraded from (the pretty old) version 2.15(20100328) to this release and the Source software doesn't start anymore.
Screenshot plugwise error after upgrade
Screen Shot 2013-05-03 at 20.33.28 .png (104.71 KiB) Viewed 19569 times
Couldn't find any installation log files that might reveal the cause of this problem.
Any ideas?
DJ
RdP
Post by RdP »
Heej,
Where did you download this release, If I remember it well there was some sort of the same error with the initial 2.23 release, but this is fixed now...
/rien
Return to “Plugwise Forum”
