Harrison curtains wired control
Has anyone tried to disassemble a Harrison unit to see if it is possible to steer the curtains using a wired controller?
Re: Harrison curtains wired control
I tried but could not easily find a possibility.
Via keyfob modification I have now made them zwave enabled.
You need just 1 Fibaro switch FGS221
I've tried the keyfob modifications also, however that did also not give me a stable environment. Hopefully Harrisson will help me with some inside details...
I'm happy with this solution.
Just sending every command twice
With a short break of 2 seconds.
- HarrisonKey.jpg (118.51 KiB) Viewed 5804 times
