smile p1 and gas
smile p1 and gas
i installed my smile today after stedin installed smartmeters. i only can see the electtric usage no gas, is that a fault of stedin ?
Re: smile p1 and gas
did you get a new "gas meter"?
yes
- p12.jpg (82.08 KiB) Viewed 6819 times
- p11.jpg (9.39 KiB) Viewed 6819 times
this is the xml file from the smile in smileip/smartmeter/modules
<?xml version="1.0" encoding="ISO-8859-1"?>
-<modules>-<module id="64e2afb3267f42c9932563b8d3af6740"><vendor_name>Xemex</vendor_name><vendor_model>XMX5XMXABCE000065904</vendor_model>-<cumulative_logs>-<cumulative_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_consumed</type><unit>Wh</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement tariff_type="nl_peak" log_date="2013-04-19T21:01+00:00">11472</measurement></period></cumulative_log>-<cumulative_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_consumed</type><unit>Wh</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement tariff_type="nl_offpeak" log_date="2013-04-19T21:01+00:00">14</measurement></period></cumulative_log>-<cumulative_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_produced</type><unit>Wh</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement tariff_type="nl_peak" log_date="2013-04-19T21:01+00:00">0</measurement></period></cumulative_log>-<cumulative_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_produced</type><unit>Wh</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement tariff_type="nl_offpeak" log_date="2013-04-19T21:01+00:00">0</measurement></period></cumulative_log></cumulative_logs>-<point_logs>-<point_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_consumed</type><unit>W</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement log_date="2013-04-19T21:01+00:00">1430</measurement></period></point_log>-<point_log><last_consecutive_log_date>2013-04-19T20:45:00+00:00</last_consecutive_log_date><type>electricity_produced</type><unit>W</unit>-<period end_date="2013-04-19T21:01+00:00" start_date="2013-04-19T10:00:00+00:00"><measurement log_date="2013-04-19T21:01+00:00">0</measurement></period></point_log></point_logs></module></modules>
you first must use gas before it is presented bij the smile. a hoax
- Jeroen Bartels
Is itsolved now?
I also just installed a smile and my gas usage is showing on the app.
**Jeroen**
yes.
