Stretch 2.0 commandline interface (PWScli)
Phoenix
Post by Phoenix »
Here is a program where you can switch your PlugWise circles from the commandline, this way you don't need complicated programmer knowledge and can use this program from a "shell" command. (think of Excel, PHP Script, Homeseer)
Download: http://domoticx.nl/plugwise-stretch-2-0 ... interface/
Tested and working on:
– Windows XP 32-bit
– Windows Vista/7/8 32/64-bit
* Does not work on Windows 95 / 98 / ME due to unicode compile.
* Does not work on Windows Server 2000 (crash)
The commandline usage of this program is: PWScli.exe switch [stretchIP] [stretchID] [applianceID/CircleName] [on/off]
[stretchIP] = The IP adres of the Stretch 2.0
[stretchID] = The Stretch 2.0 ID code (8 letters)
[applianceID/CircleName] = The 32 characters of the ApplianceID or the name of the circle
[on/off] = Switch the circle on or off
SWITCH EXAMPLES:
PWScli.exe switch 192.168.1.101 abcdefgh 71abf031c54f400ca77c8ae6957ad7cf on > Switch a circle with the proper applianceID on, via the Stretch 2.0 on IP adres 192.168.1.101
PWScli.exe switch 192.168.1.101 abcdefgh livingroom off > Switch the circle named "livingroom" off, via the Stretch 2.0 on IP adres 192.168.1.101
PWScli.exe applist [show/txt/ini] 192.168.1.101 abcdefgh > Show's or exports a list with the names and applianceID's of connected circles to a txt or ini file
INI export example:
[7adf2ef4b16b41ffad98eb9d]
name=keuken
state=off
power=0
[71abf031c54f400ca77c8ae6]
name=keukentafel
state=off
power=0
[2ef525453c764b2db87061ad]
name=logeerkamer
state=off
power=0
CHANGELOG:
v2.1 (2013-10-17)
- Solved a bug getting the proper power consumption of the circles.
- It's now also possible to switch plugs "namebased".
v2.0 (2013-10-10)
- Program adjusted for stretch 2.0 with firmware 2.0.x
- Note: This version is not compatible for a stretch with firmware 1.0.x
v1.2 (2013-05-05)
- ApplianceID and StetchID are case sensitive, now the input always get converted to lowercase!
- Checks added for the applist function.
- Build in applist extended with status en power data.
- Dump of ApplianceID's, status and power possible to txt or ini file!
v1.1 (2013-05-04)
- True CLi mode (no more messageboxes, all messages go to the prompt now)
- Build in mode to get a list of the names and appliance ID's.
- Shows status progress whenever switching a circle
- All converted to English.
NOTES:
For contact, improvements or ideas, you can contact me @ phoenixinteractive -at- hotmail -dot- com
DISCLAIMER:
* The usage of this program is at own risk!, the author cannot be held responsible for any damage to your hardware!
* Plugwise has got nothing with 'PWScli.exe' ,and will deny all responsibility.
* The PlugWise logo is and stay's the property of: http://www.plugwise.com
Huisautomatisering - Domotica - Elektronica - IT consulting - Software ontwikkeling - 3D printing - Maatwerk
Website: domoticx.nl / Webshop: domoticx.nl/webwinkel / Knowledge Center: http://domoticx.com
jeroen_
Re: Stretch 2.0 commandline interface (PWScli)
Post by jeroen_ »
Cool ;)
Phoenix
Post by Phoenix »
Thanks!, there will be an update soon -> PWScli v1.1 , i'll also convert everything to english!
Stay tuned!
Phoenix
Post by Phoenix »
Updated to 1.1 (2013-05-04):
Phoenix
Post by Phoenix »
Updated to v1.2 (2013-05-05)
great job you are doing with the Stretch
I got one Stretch myself because i want to get rid of my USB dipstick
but i see now that the stretch gives less information then the USB Stick
info i get from usb in single call via source
you see also totalusage ever, totalusage today
not possible from the Stretch so it seems??
  <id>47</id>
- <device>
- <![CDATA[ Div1
  </device>
  <devicetype>- Miscellaneous -</devicetype>
  <locked>True</locked>
  <realstate>on</realstate>
  <powerstate>on</powerstate>
  <powerusage>27.6</powerusage>
  <totalusage>45.1465</totalusage>
  <moduleid>71</moduleid>
  <macaddr>000D6F0000B81199</macaddr>
  <moduletype>Circle</moduletype>
  <room>Attic</room>
  <totalusagetoday>0.0888</totalusagetoday>
  <isonline>True</isonline>
  <lastseendate>2013-10-07 21:10:35</lastseendate>
  <lastseenseconds>136</lastseenseconds>
  <firstseendate>2012-11-25 12:37:54</firstseendate>
Phoenix
Post by Phoenix »
Hi bwired,
In the new stretch 2.0.x firmware, you can also see lot's of data including comulative logs etc...this is the data of one circle:
<appliances>
<appliance id="750a4e07ed8840528f8ceb5c313eff3d">
<name>Keukenaqua</name>
<description/>
<type>zz_misc</type>
<created_date>2013-06-28T17:36:54.479+02:00</created_date>
<modified_date>2013-10-07T22:40:02.579+02:00</modified_date>
<deleted_date/>
<services>
<electricity_interval_meter id="55967b5e5a394b51ae6821e04c8a15d4"/>
<electricity_point_meter id="5ee942a3e836424c88f5af9be73b3165"/>
<relay id="20f4d271299e4f0684a3983b858b5b20"/>
</services>
<logs>
<interval_log id="f3d44ea40bda4df89d34009e33f85a75">
<updated_date>2013-10-07T22:40:02.579+02:00</updated_date>
<type>electricity_produced</type>
<unit>Wh</unit>
<last_consecutive_log_date>2013-10-07T21:00:00+02:00</last_consecutive_log_date>
<interval>PT1H</interval>
<period start_date="2013-10-07T22:00:00+02:00" end_date="2013-10-07T22:40:02.579+02:00" interval="PT1H">
<measurement log_date="2013-10-07T22:00:00+02:00">0.00</measurement>
</period>
</interval_log>
<point_log id="65573f1097bf4a3b9cc14169fbd160a8">
<updated_date>2013-10-07T22:40:02.549+02:00</updated_date>
<type>electricity_consumed</type>
<unit>W</unit>
<last_consecutive_log_date>2013-10-07T18:06:25.739+02:00</last_consecutive_log_date>
<period start_date="2013-10-07T22:40:02.549+02:00" end_date="2013-10-07T22:40:02.549+02:00">
<measurement log_date="2013-10-07T22:40:02.549+02:00">0.00</measurement>
</period>
</point_log>
<point_log id="4bf1281102cc4fbbaf708770cc3a7d54">
<updated_date>2013-10-07T22:39:27.309+02:00</updated_date>
<type>relay</type>
<unit/>
<last_consecutive_log_date>2013-10-07T20:33:07.552+02:00</last_consecutive_log_date>
<period start_date="2013-10-07T22:39:27.309+02:00" end_date="2013-10-07T22:39:27.309+02:00">
<measurement log_date="2013-10-07T22:39:27.309+02:00">on</measurement>
</period>
</point_log>
<interval_log id="147b8e2a5c3b425ea3f15805e09bca26">
<updated_date>2013-10-07T22:40:02.565+02:00</updated_date>
<unit>Wh</unit>
<period start_date="2013-10-07T22:00:00+02:00" end_date="2013-10-07T22:40:02.565+02:00" interval="PT1H">
</period>
</interval_log>
<point_log id="4ccb216a253d492bb39ebd02eb74d5f2">
<unit>W</unit>
</period>
</point_log>
</logs>
<actuators>
<relay id="87aad1fbb6ea4737b59934eef548dd0d">
<updated_date>2013-10-07T22:39:27.313+02:00</updated_date>
<state>on</state>
<lock>false</lock>
</relay>
</actuators>
</appliance>
</appliances>
RdP
Post by RdP »
I use the 2.x Stretch firmware for a couple of weeks now. It has been a huge improvement, but the functionality is still not comparable to the Source. PlugWise is positioning the 2 products for different groups of interest and not as the Stretch will be a replacement product for the Source, however since the latest improvements the gap has become less than before.
/Rien
the new source will also support the stretch later..
but NO total- and day usage is a big miss!
updating firmware stretch now
Phoenix
Post by Phoenix »
New version of PWScli released for Stretch 2.0 with firmware 2.0.x!
v2.0 (2013-10-10)
Screen:
Enjoy!
RdP
Post by RdP »
Nice...
Thx Sebastiaan
PS net weer een update beschikbaar gekomen. Ik draai nu 2.0.16.
Gr,
Phoenix
Post by Phoenix »
v2.1 (2013-10-17)
Return to “Plugwise Forum”
