Manual force firmware update on stretch 2.0
Phoenix
Post by Phoenix »
*** USE THIS INFO AT YOUR OWN RISK!, IT'S FOR EDUCATIONAL AND LEARNING PURPOSES ***
I did get some mail about that my program PWScli (Stretch 2.0 commandline interface) did not work anymore after stretch firmware 1.0.46 (tested on 1.0.41)!
download PWScli: http://www.domoticaforum.eu/viewtopic.p ... 46&p=63305
Stretch v1.0.41 info screen:
Ps. to execute the scripts in this topic you need AUTOIT3: http://www.autoitscript.com/site/autoit/
So, with the new 2.0.x firmware plugwise did make some changes, okey knowing that...i still had the old 1.0.41, but downloading the "bleeding edge" PLUGWISE DESKTOP v1.6.7: https://securedownloads.plugwise.com/to ... _1.6.7.exe or the ANDROID APP v1.6.4, I CAN NOT UPDATE THE FIRMWARE ON THE STRETCH!
Ps. as this is written...you can only download v1.6.4 from the site : http://www.plugwise.com/nl/idplugtype-f/node/913#
https://securedownloads.plugwise.com/to ... _1.6.4.exe
So, i called plugwise why i cannot update and what is the problem, they say that the new firmware is still some buggy...so thay haven't released it the public yet...only to some "test" users!
But hey....i cannot wait ;-)
So if the apps and desktop software would not update my stretch 1.0.41 to 2.0.14 i had to do it my own!
ps. all firmwares can be downloaded here: http://phoenixinteractive.mine.nu/websi ... f=27&t=129 but there is no possibility to upload them to the stretch 2.0 and patch Linux trough SSH at the moment!
Okey, here are the steps i took:
1) HOW DOES IT WORK?
First is to look (again) how the "check for updates" button in the APPS work..., so i dismantled the DESKTOP APP (v1.6.6), as described here: http://phoenixinteractive.mine.nu/websi ... ?f=26&t=57, and this piece of code had my attention:
		public function downloadFirmware(param1:Host = null) : void
			if(param1 == null)
				param1 = this.smile;
			if(!param1.connected)
				trace("SmileModel downloadFirmware NO HOST CONNECTION");
				return;
			var _loc_4:getString = resourceManager.getString("resources", "Downloading_firmware_update_for_the_Smile...");
			this.activityText = _loc_4;
			this.errorText = _loc_4;
			this.plugwiseService.headers = {AUTHORIZATION:param1.basicAuthorizationString(), x-connection-override:"close"};
			this.plugwiseService.url = param1.hostURL(param1.port, "update/firmware");
			this.plugwiseService.resultFormat = "e4x";
			this.plugwiseService.contentType = "application/xml";
			this.plugwiseService.method = "POST";
			this.plugwiseService.requestTimeout = 0;
			var _loc_2:XML = new XML("<upgrade>\r\n\t\t\t\t\t\t\t\t\t\t<state>downloading</state>\r\n\t\t\t\t\t\t\t\t\t</upgrade>");
			var _loc_3:AsyncToken = sendHttpService(this.plugwiseService, _loc_2);
			_loc_3.action = "downloadFirmware";
		public function installFirmware(param1:Host = null) : void
			if(param1 == null)
				trace("SmileModel installFirmware NO HOST CONNECTION");
				return;
			var _loc_4:getString = resourceManager.getString("resources", "Installing_firmware_update_for_the_Smile...");
			var _loc_2:XML = new XML("<upgrade>\r\n\t\t\t\t\t\t\t\t\t\t<state>installing</state>\r\n\t\t\t\t\t\t\t\t\t</upgrade>");
			_loc_3.action = "installFirmware";
2) Okey, let's check the page/XML output of the stretch on http://192.168.x.x/update/firmware, the result is:
Okey, here is says there is a new one available!, still don't get it why i could not download it! :shock:
3) So, it seems we have to do a POST command on http://192.168.x.x/update/firmware AND PUT THE "STATE" in "DOWNLOADING"
Taking this "example" script in Autoit3, wich i wrote for the smile: http://phoenixinteractive.mine.nu/websi ... ?f=26&t=58, wich i altered a little bit so it looks like this:
Autoit3 script to let the Stretch 2.0 download the new firmware that is anounced in: http://192.168.x.x/update/firmware
; Stretch 2.0 setup
Global $StretchIp = "192.168.1.101" ;The IP adres of the Stretch 2.0, like: 192.168.1.X
Global $StretchId = "abcdfghj" ;The 8 letters of the Stretch 2.0 ID
; Kernel
Global $PostAdres = "http://" & $StretchIp & "/update/firmware"
Global $PostGegevens = "<upgrade>\r\n\t\t\t\t\t\t\t\t\t\t<state>downloading</state>\r\n\t\t\t\t\t\t\t\t\t</upgrade>"
$oHTTP = ObjCreate("winhttp.winhttprequest.5.1")
$oHTTP.Open("POST", $PostAdres, False)
$oHTTP.SetRequestHeader("Connection", "Close")
$oHTTP.SetRequestHeader("Content-Type", "application/xml")
$oHTTP.SetRequestHeader("Host", $StretchIp)
$oHTTP.SetRequestHeader("Authorization", "Basic " & _Base64Encode("stretch:" & $StretchId))
$oHTTP.Send(Linux2WinString($PostGegevens))
Global $PostResponse = $oHTTP.ResponseText
If $oHTTP.Status <> "200" Then
    MsgBox(64, "Error", $PostResponse)
Else
    MsgBox(64, "Done!", $PostResponse)
EndIf
Exit
Func _Base64Encode($sData)
    Local $oXml = ObjCreate("Msxml2.DOMDocument")
    If Not IsObj($oXml) Then
        SetError(1, 1, 0)
    EndIf
    Local $oElement = $oXml.createElement("b64")
    If Not IsObj($oElement) Then
        SetError(2, 2, 0)
    EndIf
    $oElement.dataType = "bin.base64"
    $oElement.nodeTypedValue = Binary($sData)
    Local $sReturn = $oElement.Text
    If StringLen($sReturn) = 0 Then
        SetError(3, 3, 0)
    EndIf
    Return $sReturn
EndFunc
Func Linux2WinString($data)
$data = StringReplace($data, "\r", @CR)   ; \r carriage return
$data = StringReplace($data, "\n", @CRLF) ; \n new line
$data = StringReplace($data, "\t", @TAB)  ; \t horizontal tab
Return $data
EndFunc
4) The script will output OK if all went fine:
5) Okey, now the stretch is downloading the newest firmware that is anounced, just give the stretch 1 minute and look back in http://192.168.x.x/update/firmware
The result when the new firmware is downloaded on the stretch:
6) now only one step remains, that is installing the new firmware, so looking this up in the APP the string should be "installing", so we use this code to POST it to the stretch:
Autoit3 script to let the Stretch 2.0 install the new firmware that is anounced in: http://192.168.x.x/update/firmware
; Stretch 2.0 setup
; Kernel
Global $PostGegevens = "<upgrade>\r\n\t\t\t\t\t\t\t\t\t\t<state>installing</state>\r\n\t\t\t\t\t\t\t\t\t</upgrade>"
Else
EndIf
Exit
        SetError(1, 1, 0)
    EndIf
        SetError(2, 2, 0)
    EndIf
        SetError(3, 3, 0)
    EndIf
    Return $sReturn
EndFunc
Return $data
EndFunc
7) Also this time the script will report OK if all went fine:
*** NOW WAIT CA. 5 MINUTES, THE FIRMWARE IS INSTALLING AND THE STRETCH WILL REBOOT ***
*** DO NOT TURN THE STRETCH OFF, OR DISCONNECT FROM POWER DURING THIS PROCESS ***
Tadaaa, this is how the new Stretch 2.0 firmware looks, now i can get further with PWScli! :D :D
Enjoy!
Huisautomatisering - Domotica - Elektronica - IT consulting - Software ontwikkeling - 3D printing - Maatwerk
Website: domoticx.nl / Webshop: domoticx.nl/webwinkel / Knowledge Center: http://domoticx.com
RdP
Re: Manual update firmware on stretch 2.0
Post by RdP »
I could update my Stretch using the 'normal' procedure, because I'm in the beta tester list :)
So I can't wait till you find out how to interface with the new firmware, because it looks like a lot has changed..... :(
Good luck and let me know if I need to test it....
/Rien
Phoenix
Post by Phoenix »
RdP wrote:So I can't wait till you find out how to interface with the new firmware, because it looks like a lot has changed..... :(
/Rien
I love wireshark! :lol: :lol: :lol:
See here: http://www.domoticaforum.eu/viewtopic.php?f=39&t=9007
Akatar
Re: Manual force firmware update on stretch 2.0
Post by Akatar »
<?xml version="1.0" encoding="ISO-8859-1" ?>
- <update>
- <firmware>
- <current>
<version>1.0.46</version>
</current>
- <upgrade>
<state>no_upgrade</state>
</upgrade>
</firmware>
</update>
no update for me?
RdP
Post by RdP »
And you better hurry up, because the Plugwise Plugin for Homeseer is nearly ready to be tested with 2 Stretch devices :D :D
Akatar
Post by Akatar »
but without an update..... someone trade 2 stretchen with 1.64 for 2.xxxx :D
Akatar
Post by Akatar »
RdP wrote:And you better hurry up, because the Plugwise Plugin for Homeseer is nearly ready to be tested with 2 Stretch devices :D :D
i will call plugwise tomorow to add my 2 stretches to their beta program
RdP
Post by RdP »
Good idea
For the Smile P1 is currently also a beta 2.x, may be you can ask for that also...
Let me know when it succeeds.
Gr,
Akatar
Post by Akatar »
so i called plugwise today for the beta program
i have to mail....
Akatar
Post by Akatar »
that went fast
updated both, and both are not working at the moment. normal leds are on, lan is flashing but can't connect
<?xml version="1.0" encoding="UTF-8" ?>
<system />
and thats it
to be continued
<?xml version="1.0" encoding="UTF-8"?>
-<system>-<gateway><product>stretch</product><hostname>stretch002d35</hostname><firmware>2.0.16</firmware><upgrade/></gateway><wlan0/>-<eth0><mac>78:25:44:00:2D:35</mac><ip>192.168.1.20</ip><bcast>192.168.1.255</bcast><mask>255.255.255.0</mask><proto>dhcp</proto><gateway>192.168.1.1</gateway></eth0><time>2013-10-14T17:23:02.694+02:00</time>-<timezone>
<![CDATA[Europe/Amsterdam]]>
</timezone></system>
RdP
Post by RdP »
How do you connect? Using an app or webinterface.
In case you didn't try, download the latest app for Windows, iOS etc. and try to configure the Stretch.
/Rien
Akatar
Post by Akatar »
with the app on my laptop i can connect,
i can't connect with my iphone app, with explorer or the beta plugin
Akatar
Post by Akatar »
tried a bit more
you can't acces the stretch with explorer anymore,
Firefox etc works.
Phoenix
Post by Phoenix »
Akatar wrote:tried a bit more
Firefox etc works.
True, i think it's IE9 that's having trouble, don't know about IE10 :roll: , but you can access the stretch with firmware 2.0.x in google chrome or firefox! :)
Not a good move from plugwise in my opinion, most people are still using Internet Explorer! :shock:
RdP
Post by RdP »
Safari works too, I will report the IE issue to Plugwise tomorrow :x
Return to “Plugwise Forum”
