Kaku switch in HS3
Bastiaan
Kaku switch in HS3
Post by Bastiaan »
Trying to move my Kaku switch from HS2 to HS3 but can't find the right way.
I use the 'tumble' ones with a neutral middle position, to open and close my curtains. On those are wheels to set the right code.
My other one is a double switch without and 'wheels'.
For example in HS2 I had one on B9, in the HS3 log I can see RFXCOM : (processx10) called with:B9 cmd:0 koppla:0
So the signal is there (CMD 0 and CMD 1). If I make a device with address code B9 it does not work. ALso checked the RFXCOM input devices (after a cleaning) but they don't show up.
Seems I am lost in HS3 or my Alzenheimer kicks in early. It has been a while since I installed them in HS2.....
Any advice?
b_weijenberg
Re: Kaku switch in HS3
Post by b_weijenberg »
For the new KAKU (learning mode)
In HS2 go to the RFXCOM Output device config page,
Modify the KAKU device to know the ID at Address, this ID has to be entered for the HS3 device
