Versie 3.0.0.8
Alles m.b.t. de Homeseer Xanura PMIX35, CTX15, CTX35 HS3 Plugin van sddroog (Dutch Forum)
Moderator: stefxx
stefxx
Versie 3.0.0.8
Post by stefxx »
Update: Versie 3.0.0.10: domoticaforum.eu/viewtopic.php?f=77& ... 737#p67737
Tijd voor een nieuwe versie, 3.0.0.8: http://download.dedroog.com/HSPI_A10_3.0.0.8.zip
New features:
- Remove duplicate HouseCode/DeviceCode in device config
- Report Poll status back to HS3 in GUI
- Only replace default device picture when device type changes
- First attempt to implement ExecA10 function (similar to old ExecX10 function)
-> Supporting NoCmd, All Units Off, All Lights On, On, Off, All Lights Off, Extended, Hail request, Hack Ack, Status On, Status Off and Status Request
-> Examples: hs.PluginFunction("A10", "", "ExecA10", {"P14", "On", 0, 0, False}); hs.PluginFunction("A10", "", "ExecA10", {"P14", "Extended", 25, 49, False})
Fixes:
- All new devices became A10 devices (even if not clicked "Done" on A10 tab)
- Regular dimmers did not switch on but dimmed to full
Known issues:
- Probably not all device characteristics are correct for all devices; if a device does not behave as expected, let me know
- No support for preset dim devices (these devices are rare, normal dim and extended dim works fine)
- All Lights On/All Lights Off command will not be reflected on HS3 device status/values (no way of checking if a device is configured to accept the "All Lights" codes)
- HStouch "Toggle on/off" does not work correctly with HStouch Server 3.0.0.11 and below (bugzilla #1231)
- Restart of plugin (especially after failure) fails because bug in HS3 (ComPort reverts to COM1 or 1, bugzilla #771)
ArnoB
Re: Versie 3.0.0.8
Post by ArnoB »
Bedankt weer voor de update! We gaan weer testen.
ArnoB
Re: Versie 3.0.0.8
Post by ArnoB »
Bugje gevonden:
op het nieuwe A10 tabblad bij deviceconfig, bij edit device en klik op done op A10 tabblad verdwijnt de housecode.
edit:
bij het wijzigen van de status/dim images en klik op done: housecode verdwijnt. Bij klik op Done op A10 tabblad hierna verdwijnen de dim-images 0-100, -1 en 101 blijven staan
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
Sorry, ik zie niet wat je bedoeld. Ik krijg het in ieder geval niet gereproduceerd. Kun je de exacte stappen noteren zodat ik het kan proberen te reproduceren?
Bedankt!
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
Ik zie net wel een ander klein probleempje: als je van device wisselt, veranderd het image in het oude type, niet het nieuwe :?
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
Ok, ik zie het probleem met de missende hc/dc en device images. Dat is de derde bug in HS3 die we vinden tijdens het ontwikkelen van deze plug-in :?
Zie bugzilla #1243.
Er staan nu drie issues open waar we met de A10 plug-in last van hebben. Het helpt absoluut als we allemaal even ons laten horen in bugzilla. Dan gebeurt er misschien eens wat:
Toggle On/Off in HSTouch: http://homeseer.com/bugzilla/show_bug.cgi?id=1231
Restart plug-in COM1 issue: http://homeseer.com/bugzilla/show_bug.cgi?id=771
Housecode/Devicecode missing: http://homeseer.com/bugzilla/show_bug.cgi?id=1243
Bedankt!
stefxx
Versie 3.0.0.9
Post by stefxx »
Even een kleine release: image devices worden nu correct bijgewerkt bij het aanpassen van het device type, en de MS1xA devices worden ondersteund.
Ik heb er verder niet veel aan getest... maar hier werkt het goed :D
Versie 3.0.0.9: http://download.dedroog.com/HSPI_A10_3.0.0.9.zip
New features:
- Support added for X10 motion/status only devices
- MS12A, MS13A, MS14A and MS16A devices added
Fixes:
- When you change the device type, the image "changes" to the current device, not the newly selected device
Known issues:
- Housecode/Devicecode gets removed when clicking "Done" on the "Advanced" or "Status Graphics" tabs (bugzilla #1243)
ArnoB
Re: Versie 3.0.0.8
Post by ArnoB »
We gaan weer testen. Bedankt weer voor de update!
ArnoB
Re: Versie 3.0.0.8
Post by ArnoB »
Na de update 3.0.0.9 is de html opmaak van de device management pagina helemaal om zeep. Weer snel terug naar 3.0.0.8 en alles is weer okay.
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
ArnoB wrote:Na de update 3.0.0.9 is de html opmaak van de device management pagina helemaal om zeep. Weer snel terug naar 3.0.0.8 en alles is weer okay.
Misschien even een harde refresh of de cache legen? Ik draai al weer ruim 24 uur met 3.0.0.9 zonder issues...
Bastiaan
Re: Versie 3.0.0.8
Post by Bastiaan »
Klein issue met v8 en v9 in de events:
Wanner ik deze aanmaak:
Screen Shot 2014-01-13 at 15.50.22.png (18.41 KiB) Viewed 17705 times
En vervolgens sluit, verdwijnt de Device on en veranderd het in All lights off. Misschien een nummertje vertelt in de drop down of zo?
Screen Shot 2014-01-13 at 15.50.36.png (9.18 KiB) Viewed 17705 times
PS ik zie het nu ook bij andere events gebeuren dus is een HS probleem wanneer je OR IF toevoegt aan bestaande event. Lekker weer. :?
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
Bastiaan wrote:PS ik zie het nu ook bij andere events gebeuren dus is een HS probleem wanneer je OR IF toevoegt aan bestaande event. Lekker weer. :?
Ik ben nog niet overtuigd. Zie je het ook bij andere events dan A10 triggers of actions? Het lijkt toch echt een foutje in de plugin :evil:
Had ik al gezegd dat er op A10 events geen zegen rust?
En ben je toevallig met regional settings aan het spelen geweest?
Bastiaan
Re: Versie 3.0.0.8
Post by Bastiaan »
Haha mijn zegen heb je wel :-)
Nee ik denk toch dat het een meer algemeen HS3 issue is. Ik heb het net met wat RFXCOM events geprobeert en kan het reproduceren.
OR IF is buggy. Ik wacht even op de HS3 update deze week, als het blijft wordt het tijd voor bugzilla.
Nee geen veranderingen aan regio settings.
stefxx
Re: Versie 3.0.0.8
Post by stefxx »
Bastiaan wrote:Nee ik denk toch dat het een meer algemeen HS3 issue is. Ik heb het net met wat RFXCOM events geprobeert en kan het reproduceren.
Ik heb het kunnen reproduceren met en zonder OR IF. En erger nog, ik had de plugin aan het crashen tijdens het testen, dus ook maar gelijk wat extra checks ingebouwd. Test even 3.0.0.10, daar is het in opgelost denk ik. Mocht het wel een HS3 issue zijn verander ik het volgende week wel weer terug. Uiteindelijk is het toch slechts een display issue, alles werkt gelukkig wel gewoon :D
stefxx
Versie 3.0.0.10
Post by stefxx »
Versie 3.0.0.10: http://download.dedroog.com/HSPI_A10_3.0.0.10.zip
Fixes:
- Event triggers and actions displayed the wrong command
- Incomplete triggers and actions could crash the plugin
Known issues:
Return to “Homeseer PMIX35, CTX15, CTX35 - Plugin HS3”
