SAX35
labtec
SAX35
Post by labtec »
Is there an other way to program a SAX35 module? I don't have a PMIX35 or Marmitek X10 control box.
Is it possible to send the desired X10 code via Homeseer through a CM11 or with a Marmitek remote control? or?
Thanks.
vasco_nl
Re: SAX35
Post by vasco_nl »
I programmed a DAIX12 and SAIX12 through HomeSeer with the Marmitek CM15a. Do not know if it will also work with a Marmitek CM11. I know that it will not work with the not original Marmitek CM15a (there are a couple of copy cats out there) that I own (Powerhouse).
But if you have HomeSeer and a CM11 just try yourself and let us know the results.
Disneyland, een mensenval bediend door een muis!
