GreenWave Unknown (powernode)
Posted: Sat Mar 08, 2014 11:24 pm
by FoRMaTC
I bought two powernodes (6 ports) Nuon aka Greenwave.
They have different firmware versions and the settings are different as well in openzwave control panel (see attached photo).
The problem I have is that I can't reset the values like the other powernode and also a lot of unknowns are there
Is there a way to put a new firmware on there?
Bjorn
Re: GreenWave Unknown (powernode)
Posted: Tue Mar 11, 2014 11:50 pm
by FoRMaTC
140 views..... no one?
Posted: Wed Mar 12, 2014 1:05 am
by GertK
You cannot update the firmware of the Greenwave Powernodes. Why would you want that ?
You can lookup how to configure them elsewere in this forum. The most important setting is parameter 1 the no communication timeout in minutes. If you do not poll the device before this timer times out, the big green light around the mains switch starts flashing.
Gert
Posted: Wed Mar 12, 2014 12:43 pm
by FoRMaTC
I understand but why do I have no totals with node8 while I have them with node7.
Also I have different Library/ Protocol and Application versions between node7 and node8
Posted: Wed Mar 12, 2014 1:51 pm
by FoRMaTC
Also I can not read the configuration out of node8.
I will reset the device maybe that will help
Posted: Sun Mar 16, 2014 3:37 pm
by uAlex73
Do you have a copy of your zwcfg*xml? Then I can compare it with my powernodes (i got both 1 and 6 port versions).
Posted: Tue Mar 18, 2014 11:53 pm
by FoRMaTC
I'm using domoticz and I assume it is in the Config directory
Attached the file
Bjorn
Posted: Fri Mar 21, 2014 2:12 pm
by FoRMaTC
Hoi,
Heb het al opgelost
Aan de hand van
http://www.domotiga.nl/projects/domotig ... _OpenZWave (Unknown device in Z-Wave Commander):
<Manufacturer id="0099" name="GreenWave">
<Product type="0002" id="0002" name="PowerNode 1 port" config="greenwave/powernode1.xml"/>
<Product type="0003" id="0004" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
is nu:
<Product type="0003" id="0006" name="PowerNode 6 port" config="greenwave/powernode6.xml"/>
</Manufacturer>
Posted: Sun Mar 23, 2014 11:15 am
by uAlex73
Can you open a ticket with open-zwave, that they add this combination to their xml file? Else it is lost during every upgrade ... and you are helping other people too.
https://code.google.com/p/open-zwave/issues/list
And click on "New issue"
