Washing Machine - Ready
Posted: Mon Aug 18, 2014 11:23 am
by raymonvdm
In the past i tried to achieve the following solution but without success
I want to notify the wife of our washing machine status, she always forgets to empty it after it is finished. The washing machine is plugged into a Plugwise module and the power usage is 2 or 3 watt when idle.
I created an event:
Name: Washing Machine is Ready
Cannot Retrigger for: 3600 seconds
Trigger Type: Device Value Change
Select Days: All Days
Apply Conditions: Device "Wasmachine Plugwise" value does not equal 0
Device Value: "Wasmachine Plugwise" less than 20
Action: Send email to wife@domain.net
but i think there is a better way to do this using a script. Does anyone uses a script ? And do you take in account the moment when the washing machine is waiting for "inweken" and the power usage drops to 3 watt it will also notify and therefore sends a false positive
I also would like to have a second script to remind her of the washing machine status
If device status is 2 or 3 watt for at least 2hrs send notify, but this is not possible using events. And because of the toggling between 2 and 3 watts on idle i cannot use "device status changed" field
Re: Washing Machine - Ready
Posted: Mon Aug 18, 2014 11:40 am
by bartbakels
I use this for me washingmachine, dryer and dishwasser, in HS3 by utilizing timers, and only checking the timer is running and power is less then for X minutes.
regards
Bart
Posted: Mon Aug 18, 2014 11:45 am
by AshaiRey
I do something like this.
Make virtual device and turn that On when your plugwise device > 4W and off when below that
Now you can trigger an event with the condition 'at least'
When you use a time of something like 20 min. it will cover the false trigger too for 'inweken'
The value equals 0 condition is there to trigger this event only once. In the action list of this event i set the device value to 50 so this event won't trigger again.
When the washing maschine is started again this value is set back to 0
Posted: Sat Sep 06, 2014 10:36 pm
by raymonvdm
I just made a similar setup but without the condition because it has hung up homeseer in the past, and therefore i`m not using conditions
Full Version
