Today i upgraded the firmware of the nodeMCU (wifi) that is on my OTGW. I think my nodeMCU is off an older type (with ESP8266).
I used firmware ESP_Easy_mega_20231013_normal_ESP8266_4M1M
The previous firmware was 5 years old (2018).
I can acces the webpage of the nodeMCU.
What are the correct settings at the "Devices" tab for the Serial server?
Anything else i can check to get it working and communicating back to Domoticz?
Domoticz is showing
2023-11-23 15:23:07.954 Status: OTGW: connected to: 192.168.0.220:6638
But in fact the OTGW "sensors" are not updated.
Upgraded ESP Easy, Domoticz cannot connect to OTGW anymore
- Starting Member
Re: Upgraded ESP Easy, Domoticz cannot connect to OTGW anymore
Hi, can you try this? Especially your serial settings seems not OK.
I recently stepped over from v147 (!) to mega-20230507.
For me it.s OK.
Also tried the new MQTT softwaren from NoDo shop but to much errors for me and missing the setpoint overrule option.
Succes!
-Bart
For me it.s OK.
Succes!
-Bart
- OTGW3.jpg (64.19 KiB) Viewed 1787 times
- OTGW2.jpg (83.82 KiB) Viewed 1787 times
- OTGW1.jpg (57.52 KiB) Viewed 1787 times
