OTGW monitor displays Bad Request messages
wimvandermaaten
Post by wimvandermaaten »
For example, when entering the command GW=1, the OT monitor gives the answer: HTTP/1.1 400 Bad Request
What is going on here?
Re: OTGW monitor displays Bad Request messages
Works for me (webserver configured for http on port 1480):
Via: http://localhost:1480/configure.html, Miscellaneous tab:
10:12:30.614655	Command (via websocket): GW=1
10:12:30.640845	GW: 1
Using: `wget -qO- http://localhost:1480/command?GW=1`
10:12:37.559266	Command (via web API from ::1:58020): GW=1
10:12:37.584049	GW: 1
Or with curl:
curl -v http://localhost:1480/command?GW=1
*   Trying 127.0.0.1:1480...
* Connected to localhost (127.0.0.1) port 1480 (#0)
> GET /command?GW=1 HTTP/1.1
> Host: localhost:1480
> User-Agent: curl/8.0.1
> Accept: */*
< HTTP/1.1 200
< content-type: text/plain
< content-length: 5
* Connection #0 to host localhost left intact
GW: 1
wimvandermaaten
Doesn't work for me (with the web server on port 80)
None of the three proposed codes, entered via the Miscellaneous tab, work properly. Each time the command GW=1 gives the following response:
For example:
Scherm­afbeelding 2024-01-01 om 17.43.26.jpg (18.85 KiB) Viewed 2950 times
Ah, so it's not OTmonitor that gives the answer "HTTP/1.1 400 Bad Request". OTmonitor only reports that whatever it is connected to produced "HTTP/1.1 400 Bad Request". So it seems that you are not connected to the serial data port of the OTGW.
From a previous post I understand you have an OTGW with a Wemos module running the OTGW-firmware by rvdbreemen. With that configuration you need to connect OTmonitor to port 25238 at the IP address of the Wemos. My guess is you connected to port 80 instead.
wimvandermaaten
Ja. Ik geloof dat nu alles werkt. Bedankt.
Translation:
Yes, I think everything works now. Thanks.
