For example, when entering the command GW=1, the OT monitor gives the answer: HTTP/1.1 400 Bad Request
What is going on here?
OTGW monitor displays Bad Request messages
- Starting Member
Re: OTGW monitor displays Bad Request messages
Works for me (webserver configured for http on port 1480):
Via: http://localhost:1480/configure.html, Miscellaneous tab:
Using: `wget -qO- http://localhost:1480/command?GW=1`
Or with curl:
10:12:30.614655 Command (via websocket): GW=1
10:12:30.640845 GW: 1
10:12:37.559266 Command (via web API from ::1:58020): GW=1
10:12:37.584049 GW: 1
curl -v http://localhost:1480/command?GW=1
* Trying 127.0.0.1:1480...
* Connected to localhost (127.0.0.1) port 1480 (#0)
> GET /command?GW=1 HTTP/1.1
> Host: localhost:1480
> User-Agent: curl/8.0.1
> Accept: */*
< HTTP/1.1 200
< content-type: text/plain
< content-length: 5
* Connection #0 to host localhost left intact
GW: 1
- Starting Member
Doesn't work for me (with the web server on port 80)
None of the three proposed codes, entered via the Miscellaneous tab, work properly. Each time the command GW=1 gives the following response:
For example:
For example:
- Schermafbeelding 2024-01-01 om 17.43.26.jpg (18.85 KiB) Viewed 2951 times
Ah, so it's not OTmonitor that gives the answer "HTTP/1.1 400 Bad Request". OTmonitor only reports that whatever it is connected to produced "HTTP/1.1 400 Bad Request". So it seems that you are not connected to the serial data port of the OTGW.
From a previous post I understand you have an OTGW with a Wemos module running the OTGW-firmware by rvdbreemen. With that configuration you need to connect OTmonitor to port 25238 at the IP address of the Wemos. My guess is you connected to port 80 instead.
- Starting Member
Ja. Ik geloof dat nu alles werkt. Bedankt.
Translation:
Yes, I think everything works now. Thanks.
Translation:
