I have a problem with the following setup.
I have a switch type WST-8800 with code K3. This switch isn't detected by RFXCom. How can i add this one?
This switch operates a ACM-1000 module that will get it's code automatically. Now i would expect that the send code would be K3 send by the switch and that will trigger the ACM-1000. If i setup an output decive as follow
If i then try to switch it in the device window it will not work.
There is a second problem but this one is the reverse of the previous one.
I have also a AWST-8800 double switch. This one is detected by RFXCom as seen below
This double switch operates also a ACM-1000 but i can't figure out which code this switch transmits. If i use the RFceiver.exe program nothing shows up in both occasions.
Please advice.
Please note:
All is working by operating the switches manually but i can get them working in HS + RFXCom
Thanks,
