My led thingy..
Moderator: Mversluis
- Snelvuur
- Forum Moderator
- Contact:
My led thingy..
So i ordered a bunch of stuff from marco (moodledlight) and he came over so we could get some work done.. loads of dmx stuff (finally) went into the house.
as a small peak i have a picture of the kitchen floor (made by iphone, so dont blame me) once the rest of all the bits are in place i'll make some proper pictures and stuff.
- Fantic
- Member
- Contact:
Re: my led thingy..
Looks a bit bright, or is that the iphone cam?
I'm still working hard to get everything in place but we are getting closer and closer. Bathroom almost done, for the hallway downstairs just received the led lights, the kitchen will be placed in mid jan so will show some more picts by then.
- thmb_IMG_7781.jpg (39.77 KiB) Viewed 12899 times
- Snelvuur
- Forum Moderator
- Contact:
Re: My led thingy..
its just the iphone indeed, it looks much nicer in real live. You got a boat house on the picture? Nice to place some lights "in" the water
- Fantic
- Member
- Contact:
Re: My led thingy..
Indeed it is a houseboat, there is 1 light 'in' the water, in my bathtub and I think it is not going to increase soon. There are however many planned below water-level, as this is around 1,50 from the ground-floor. I'm going to put LED strip in alu strips in the ceiling of the bathroom, underneath the sink and the bathtub. Also under each step of the staircase and as you have it underneath the kitchen. In the hallway downstairs I will put 3 down lights and 5 led 1w spots in the ceiling.
All will be the Warm White color as neither of us likes the coloring thing with RGB.
As soon as things are in place, I will post some more pictures of how it all works out.
Regards, Maarten.
- Fantic
- Member
- Contact:
Re: My led thingy..
In the mean time I was able to put some more Led light to work, in the bathroom I have integrated a aluminum U shaped strip in the ceiling with a milky white cover, inside the Warm White LED strips have been placed, in total around 7 ( 2 x 1 and 2 x 2,5) meters and 1 meter underneath the cabinet.
The 2 short ones and the cabinet strip are connected to the one dimmer and the 2 long ones are connected to another dimmer.
The effects (no flash was used): For the kitchen this is a first glimps:
Regards, Maarten.
Re: My led thingy..
are you able to control it via homeseer (including dim function) and where did you get the alu strip and milky white cover?
** edwin **
- Fantic
- Member
- Contact:
Re: My led thingy..
The Warm White LED strips are not RGB, so the color change will be very difficult
The Alu strip I bought at Mood-Ledlight, however it was not on his website, we've been searching a while for it.
A close-up of the strip (built flat into ceiling) the strip was first put onto the wood then the plaster plates were put around and after that the ceiling was finished by 'stucadoors' Before they came in we replaced the alu strip with wood same width (16mm) and 16mm thick, after that we waited a couple of days for the wood and the plaster to let go of each other so we could remove the wood and replace the alu strip. As this is only 12mm thick we needed to add some nuts under each screw, I used the type used in 19" racks as they got closest to what I needed. All 4 pieces could be controlled separately if I want. I'm working on getting all these things controlled by Homeseer, however my wallet is kinda empty, so no Zwave components for the first couple of months, I'm afraid. I do have some drivers/dimmers that are controllable by a pushbutton, push on, push off, hold dim up or down. this could also be controlled with a 1-10V input, which can be built with some components with a analog output.
Regards, Maarten.
- Fantic
- Member
- Contact:
Re: My led thingy..
Just another update:
Regards, Maarten.
- Fantic
- Member
- Contact:
Re: My led thingy..
The kitchen part with some better picts:
I needed to put the LED strip on a Aluminum L (10x20mm) shaped strip, so I could remove when needed and also due to the fact that the door fronts do not extend down past the bottom of the cabinet and from a distance you could see the dots of the LEDs. Now the L strip is masking the view.Regards, Maarten.
- Snelvuur
- Forum Moderator
- Contact:
Re: My led thingy..
i like the hallway lights, those are things you need to consider when building .. not something you can easilly add later on.
- Fantic
- Member
- Contact:
Re: My led thingy..
Indeed those are quite big, about 12cm and 8cm deep.
Regards, Maarten.
