New beta Plugwise Source 2.15 Beta 20100325 (release candida
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report.
You can find it in the bottom right of the blue title bar.
Plugwise Source 2.15 Beta 20100325 (release candidate)
Fixed:
-#881 PTE: Appliance.NotInNetwork returns FALSE, if appliance has no module
-#880 Server: tray icon shows error message, even when there was no error.
-#868 Switching to German crashes Source at next startup
-#875 Uninstall does not remove all files
-#847 Update button seems to hang when pressed a second time
-#760 After update, room types are gone
-#403 Windows Vista asks for network credentials when Plugwise Update is running
Changes:
- Splash screens do now show application name and version.
- After firmware update, schedules are resend if needed and enabled
- PTE: You can now render the same graphs as in the Reports screen of Source through /pwgraph/.
See new index.html for an example (SettingsProgram, click webserver URL).
Known issues:
- English manual need updating
- German manual missing.
Notes:
- If you're having unexplainable holes in the graphs of one ore more appliances do the following. In the Reports screen, select the appliance, click the refresh button while holding down the Shift key and then wait for a few minutes.
Plugwise Source 2.15 Beta 20100319
Changes:
- PTE: Webserver is now multi threaded, especially Pro users will notice a big performance gain
- PTE: All icons served through /pwimg/ are now transparent PNG's
Plugwise Source 2.15 Beta 20100316
Fixed:
-#833 PTE: Blank password is accepted, even when a non blank password is configured.
-#832 Config: If Stick is linked to different C+ on other system, original system keeps expecting previous C+
-#831 Reports: Revenue not included in export
-#830 Reports: Revenue not shown in Costs graph
-#787 Reports: Dense graphs show hours on x-axis instead of dates
-#727 Pro: Cannot merge networks that contains migrated modules.
-#634 Schedules: Standby only works at beginning of standby period.
Changes:
- If Source is started while Server is running, Server exits. When Source exits, Server is restarted. Same thing vice versa.
- Upon start, if schedules on modules and in Source differ, a message is displayed.
- After sending schedules, a success or failure message is displayed.
- Standby values must be set in increments of 5 Watts
Plugwise Source 2.15 Beta 20100310
Fixed:
-#822 TotalUsage no updated every hour
-#821 Must 'Run as Administrator' to use webserver on Windows Vista and Windows 7
-#816 Reports: graph uses peak/offpeak in weekends
-#817 Reports: long frees after clicking Export on system with large database
-#783 Reports: No hourly graphs unless period is 3 days of longer
Changes:
- Source no longer requires 'Run as Administrator' to enable the webserver.
- PTE: HTML output defaults to chartype=utf-8 (/sys/mimetypes.txt)
- German translation
Fixed:
Changes:
Known issues:
Notes:
Changes:
Fixed:
Changes:
Fixed:
Changes:
Re: New beta Plugwise Source 2.15 Beta 20100310 Released
This version indeed fixed the problem updating the totals, both in the Source Appliances view as well as in the web server.
Re: New beta Plugwise Source 2.15 Beta 20100316 (RelC) available
New beta update 2.15!
Today a new Source Beta version (Plugwise Source 2.15 Beta 20100316) is released.
BIG PROBLEM !!!
The source software can't communicate with the stick, so no communication at all.
However, the plugwise server does work without any problem.
I wanted to check if the standby function issue was solved, but I'm unable to test this with a non-working source.
Am I the only one with this problem, or just the first one who installed it ??
/Rien
/Rien
For what is it worth, this version works fine for me.
Schedules seem to work too.
No problem at all, everything is working fine for me.
Also the schedule behaviour is perfect right now!
@Rien,
I find your experience very strange, not heard before.
Could it be that you choose to update the driver? That could explain this.
Than you just unplug the stick and plug stick back in again.
Please let us now if the issue is solved in your situation.
It is strange. As I said the plugwise server is running without a problem(also with the HS plugwise plugin), but as soon as I start the source there's no communication at all.
I did not install a new driver...
The update wizzard is also stopping (nakijken plugwise netwerk) during the update process
I will try and unplug the stick...
/Rien
/Rien
No, still the same problem... See screenshot
- 2010-03-18_1117.png (102.19 KiB) Viewed 14152 times
Hmmm....that's really strange.
Maybe you can try running the update by setup http://www.myplugwise.com/source/pwsetup2.15beta.exe
This will also change the version to .1 (minor change).
Maybe you start first the dedicated web server and after that the Source.
That's not possible. So I would suggest. Kill all Plugwise processes (webserver and ....).
Disconnect stick wait a few second and reconnect again.
Start only the Source (so without de dedicated webserver).
I am convinced it's not a problem in this version of the Source.
I did update to the current version of the beta (20100316.1).
As before -#816 Reports: graph uses peak/off-peak in weekends is NOT fixed:
The hourly utilization represents the off-peak usage during the weekends correctly
BUT
The daily utilization graph still shows both peak and off-peak utilization (should be only off-peak utilization in the weekend).
---- UPDATE ---
Not sure what the logic is, but looking again at the graphs (an hour later or so), it suddenly shows correctly only off-peak usage in the daily graphs. Would appreciate if somebody can explain how this is supposed to work......
BUT
---- UPDATE ---
I uninstalled and installed the beta software al over again, but with the same result.Reinder wrote:Hmmm....that's really strange.
I'm lost now....
Does someone have a 3.14 version for me ??
IK heb 3.14 inmiddels
Ben terug gegaan naar 3.14 en het werkt weer voor 100 %. Weer een upgrade gedaan naar de laatste beta en het probleem is weer terug !!!!
Dus het moet toch echt aan de source software liggen, alhoewel ik de enige ben die er last van heeft. Met 3.14 werkt het gewoon.
Ik zie het stick icontje af en toe wel oplichten (1 a 2 seconden) maar er gebeurd verder niks.....
hmmmm. that's absolute very strange. As far as I know, your are the only one...
