Siren and Smoke Detector (flex-control)
PSL74
Post by PSL74 »
I use Homeseer HSPRO 2.4.0.25
I bought Siren SE812-1 and Smoke detector SF812-1 (http://www.flex-control.dk).
The instruction says that The Siren and Smoke Detector supports Command Classes including:
*COMMAND_CLASS_ASSOCIATION V2
*COMMAND_CLASS_BATTERY
*COMMAND_CLASS_BASIC
*COMMAND_CLASS_VERSION
*COMMAND_CLASS_MANUFACTURER-SPECIFIC
*COMMAND_CLASS_SENSOR_ALARM (Smoke detector)
*COMMAND_CLASS_SWITCH_BINARY (Siren)
This is what came up in the logs when I imported devices:
SE812-1 (flex-control)
27.06.2010 22:09:19  - Z-Wave - ********** Adding Z-Wave Device with Node ID of 8 Type GENERIC_TYPE_SWITCH_BINARY=10H **********
27.06.2010 22:09:19  - Z-Wave - Contacting node 8 to get supported features
27.06.2010 22:09:20  - Z-Wave - Attempting to get manufacturer ID from device 8...
27.06.2010 22:09:21  - Z-Wave - Z-Wave manufacturer ID: 96=60H (Everspring), Type: 12=CH, ID: 1=1H
27.06.2010 22:09:21  - Z-Wave - Device: Z-Wave Z-Wave Interface  (Node 8) supports class(es): COMMAND_CLASS_SWITCH_BINARY, COMMAND_CLASS_VERSION, COMMAND_CLASS_BATTERY, COMMAND_CLASS_ASSOCIATION, COMMAND_CLASS_MANUFACTURER_SPECIFIC
27.06.2010 22:09:23  - Z-Wave - Z-Wave device 8 version: Lib: 2.64 App: 1.3
27.06.2010 22:09:25  - Z-Wave - Device supports 1 groups for associations
27.06.2010 22:09:26  - Z-Wave - ********** Done with Z-Wave Device with Node ID of 8 **********
27.06.2010 22:09:29  - Device Update - Device: Z-Wave Z-Wave Interface Child 8 Battery Battery Level 90%
27.06.2010 22:09:29  - Device Update - Device: Z-Wave Z-Wave Interface Child 8 Switch Binary Status set to OFF
SF812-1 (flex-control)
27.06.2010 22:17:36  - Z-Wave - ********** Adding Z-Wave Device with Node ID of 9 Type GENERIC_TYPE_SENSOR_ALARM=A1H **********
27.06.2010 22:17:36  - Z-Wave - Contacting node 9 to get supported features
27.06.2010 22:17:36  - Z-Wave - Attempting to get manufacturer ID from device 9...
27.06.2010 22:17:37  - Z-Wave - Z-Wave manufacturer ID: 96=60H (Everspring), Type: 13=DH, ID: 1=1H
27.06.2010 22:17:37  - Z-Wave - Device: Z-Wave Z-Wave Interface  (Node 9) supports class(es): COMMAND_CLASS_MANUFACTURER_SPECIFIC, COMMAND_CLASS_VERSION, COMMAND_CLASS_ASSOCIATION, COMMAND_CLASS_BATTERY, COMMAND_CLASS_SENSOR_ALARM
27.06.2010 22:17:37  - Z-Wave - Z-Wave device 9 version: Lib: 2.64 App: 1.4
27.06.2010 22:17:38  - Z-Wave - Device supports 1 groups for associations
27.06.2010 22:17:38  - Z-Wave - Alarm Sensor Node 9 Supports 1 Alarm Types: SMOKE_ALARM
27.06.2010 22:17:38  - Z-Wave - ********** Done with Z-Wave Device with Node ID of 9 **********
The problem is that I can not send a command to activate the Siren, and when clicked on tamper switch Siren begins to sound, but in the logs appears:
Warning - In Set Level for device Z-Wave Z-Wave Interface Root Device 8 which does not match command type Alarm, and its actual device could not be located - cannot continue.
When the smoke detector is triggered, HomeSeer does not respond.
What I did wrong?
Thanks in advance
talisman
Re: Siren and Smoke Detector (flex-control)
Post by talisman »
Personally I disabled the tamper alarm because I almost lost my hearing ;)
No issues with the siren besides that - You could try and disable it as well (one of the jumper settings I believe) just on the of chance that this does the job.
Also for the smoke alarm - it looks like you haven't scanned it properly - try doing a rescan just on the device (while pressing the little button on the inside) to see if you get all the devices - it should have a battery, root device and sensor.
-- Sorry I didn't look properly - you do have all the devices - what works for me is press the alarm test button so it updates homeseer (cover your ears though ;) ) but doing a rescan and a few optimises would prolly not hurt either.
cheers,
elco
PSL74
Post by PSL74 »
HI, Elco
After upgrading HomeSeer to 2.4.0.56 in the logs appears supporting COMMAND_CLASS_ASOCIATION_V2, I managed to get to work Smoke Detector, by pressing link key and while it stay awake add homeseer in asociation.Thanks
But with the siren all the same thing, I still cannot activate the siren, turning the switch binary to ON.
Can you write in more detail what Siren do you have and how to make it work?
I am trying to configure it for almost a week.
Thank you!
talisman
Post by talisman »
I have the same siren you have (the only z-wave siren that is avaiable in europe afaik)
When I set it up I just added the device using the Aeon stick, then I closed the thing up, tried optimising, found out that the listening period was short so I had to open it up again t opress the button so it would listen - then when I opened it the tamper alarm went off rendering me almost deaf in the process, so I took the jumper out. Then I just scanned again to get all information and optimized untill it had enough neighbors - also it is one of the rare battery operated devices I've found that can be awakened from homeseer, i.e. it's a listener so it should resond to your signals een without pressing the button (though it may take a minute or so)
It's functioned fine really, not sure what else to suggest - though you could try removing and re-ading the device from your z-wave controller (and ofcourse from homeseer)
Hope that helps
Elco
Return to “Z-Wave Forum”
