I tried also the standard, classic and the touch screen. All are succesfull introduced in HStouch this afternoon.
It is also recommend that you update to HSTouch server plugin 1.0.0.12 and the Squeezebox plugin 2.0.0.1 Beta.
And I used a normal textbox in HSTouch and changed the IsHTML=True and also AllowNavigation=True.
After this I brought in the IP-adress where Squeezebox is running on.
And it works by mine fine.
B.R. Wim
