FHEM supports RFXMeter
Moderator: b_weijenberg
Kroonen
Post by Kroonen »
With much help of Willi Herzig, we got in fhem also support for the rfxmeter.
Here some screenshots and configs
RFXMETER:
RFXGas (CNT: 2104.17)
RFXPower (CNT: 7820.434)
RFXWater (CNT: 211419)
fhem> l RFXPower
Internals:
CODE 01
DEF 01 0.001 kwh
IODev RFXCOM
NAME RFXPower
NR 9
STATE CNT: 7820.451
TIME 2011-01-05 20:14:52
TYPE RFXMETER
scalefactor 0.001
unitname kwh
Readings:
2011-01-05 20:14:52 meter 7820.451 kwh
Attributes:
room RFXMETER
fhem> l RFXGas
Internals:
CODE 02
DEF 02 0.01 cu_m
IODev RFXCOM
NAME RFXGas
NR 12
STATE CNT: 2104.2
TIME 2011-01-05 20:15:24
TYPE RFXMETER
scalefactor 0.01
unitname cu_m
Readings:
2011-01-05 20:15:24 meter 2104.2 cu_m
Attributes:
room RFXMETER
fhem> l RFXWater
Internals:
CODE 00
DEF 00 0.5 ltr
IODev RFXCOM
NAME RFXWater
NR 6
STATE CNT: 211429
TIME 2011-01-05 20:15:23
TYPE RFXMETER
scalefactor 0.5
unitname ltr
Readings:
2011-01-05 20:15:23 meter 211429 ltr
Attributes:
room RFXMETER
jrkalf
Re: FHEM supports RFXMeter
Post by jrkalf »
Looks excellent, it got my interest spiked into probably using this for "meterkast" measurements :)
But not to ruin the party too much. I'll have to ask one of the global moderators to move this small bit towards the RFXcom forums as this post is a pure RFXcom party :)
ELV FHT80b heating system.
Kroonen
Post by Kroonen »
There should be maybe an softtware fhem topic??/
jrkalf
Post by jrkalf »
I must say there'll be a FHEM influence in this sub-forums a lot, but that mainly due to the software availability (open source) for the FS20 devices.
I've solved it by "moving" it to the right subforums but leaving a shadow post in here.
jrkalf
Post by jrkalf »
Speaking of FHEM... Have you adressed this nice progress to the fhemobile dev already so he can incorporate the graphics onto your iPad/iPhone/iPod? :mrgreen:
Kroonen
Post by Kroonen »
Well there is no support form fhemobile yet, but in the next version the oregon sensors will be supported.
For support for the rfxcommeter, I must know how de em1010wz looks like so I can look how to get the rfxcommeter supported.
There is also a way to make fake devices on fhem, and run a script and trigger values
for example, now I make from an oregon an HMS device, to see it in fhemobile
#!/bin/sh
datum=$(date +%Y-%m-%d)
tijd=$(date +%H:%M:%S)
temp=$(/usr/bin/tail -n1 /var/log/fhem/buiten-2011.log | cut -d " " -f4)
hum=$(/usr/bin/tail -n1 /var/log/fhem/buiten-2011.log | cut -d " " -f7)
/usr/bin/fhem.pl localhost:7072 'trigger Buitentemp T: '$temp' H: '$hum' Bat: ok; {\
$defs{Buitentemp}{STATE}="T: '$temp' H: '$hum' Bat: ok";;\
$defs{Buitentemp}{READINGS}{temperature}{VAL}="'$temp' (Celsius)";;\
$defs{Buitentemp}{READINGS}{temperature}{TIME}="'$datum' '$tijd'";;\
$defs{Buitentemp}{READINGS}{humidity}{VAL}="'$hum' (%)";;\
$defs{Buitentemp}{READINGS}{humidity}{TIME}="'$datum' '$tijd'";;\
$defs{Buitentemp}{READINGS}{battery}{VAL}="ok";;\
$defs{Buitentemp}{READINGS}{battery}{TIME}="'$datum' '$tijd'"}'
jrkalf
Post by jrkalf »
em1010wz, I don't think that device exists. Do you mean the EMwz (em1000wz) or the EMpc (em1010pc).
Anyway, if you need information on the em1000wz, let me know. I have one incoming in this weeks ELV shipping :)
I'm not a super techy dude, but tell me what to monitor and I'll send you a dump of the em1000wz communications.
Jelle
