ISKRA ME162
s8utt
ISKRA ME162
Post by s8utt »
Hello, I've just had some solar panels fitted and now I need to monitor 3 seperate electrical usages
Import
Export
Generation
From this I can calculate what the house has used.
So I've got 3 Iskra ME162 meters installed. on each meter there are 2 pinouts, 60 and 61 I'm told they are pulse ouputs
The exact model number is ME162-D3A51-L11-M3K0
http://www.iskranet.co.uk/index.php?cat ... 2a92628fd7
"This meter also has the facility for a pulsed output for an energy management system or AMR The pulse output is via the Auxiliary terminals indicated as 60, 61 for terminal connection to BS5685"
Does anyone know what the pulse output will look like ?
I understand it will probably be a square wave, as per http://openenergymonitor.org/emon/node/79
but will it be a dc voltage, say 5v base, 6v peak or will it be a simple closing contact ?
Any suggestions are welcomed as I'm a bit lost
Cheers
erisan500
Re: ISKRA ME162
Post by erisan500 »
Usualy it is an Open Collector output. In the manual/datasheet/mounting instructions, you should be able to find the allowed voltage range you can use, but consider 5V as safe.
s8utt
Re: ISKRA ME162
Post by s8utt »
ok not sure i understand :(
i connect a voltage to that pin ? it then changes the constant voltage into a pulse that you can read ?
Re: ISKRA ME162
there is also an optical port on your meter
You can use this with ir sensor also to count pulses and probably get the Text of the counters
s8utt
Re: ISKRA ME162
Post by s8utt »
yes there is an flashing LED, this is how I'm recording it at the moment
I suppose I'm being picky but I wanted to leave the led uncovered so I myself could see it flashing or not.
A quick look, I can tell if I'm generating / exporting or importing.
Re: ISKRA ME162
thats not what i mean, a flashing led is different
the IR port is the big opening with a diode in the middle
you cant see it flashing
CowboyTW
Re: ISKRA ME162
Post by CowboyTW »
I also have a ISKRA (different type) with such a IR port.
Wonder how you can interact with it without having a engineering password or pin or whatever needed to access the data.
If I can get readonly access to retreive the data found on te LCD screen I would be very happy.
Any idea how to do this?
Tom
-=Professional Domotica Newbie!=-
Re: ISKRA ME162
This is how i do it for my Itron (Actaris ace3000), gives you an idea
http://www.bwired.nl/weblog.asp?id=429
CowboyTW
Re: ISKRA ME162
Post by CowboyTW »
Super Thanks, this helps me getting started!
zass
Re: ISKRA ME162
Post by zass »
Very interesting topic. Do you have any results reading out the ME162? I have the same meter and I am looking for a readout via IR as well...
